It is currently Tue Aug 11, 2026 12:09 pm
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jan 31, 2017 2:03 am
Hi all
My first post here . I have a 2010 Jimny Auto and would like to fit a M18a engine . Will this engine mate to the Auto ?
Any help would be appreciative .
Post Posted: Tue Jan 31, 2017 6:51 am
Yes it will bolt together.
The m18 produces far more torque than the torque limit of the auto (which is basically 110nm) run the biggest cooler you can and a trans temp gauge. It will get HOT.
Post Posted: Tue Jan 31, 2017 10:48 am
Thanks for your reply . I am going to run a large cooler . Have you done this exercise yourself ?
Post Posted: Tue Jan 31, 2017 11:47 am
No, but I am familiar with the maximum torque rating of the auto and how hot they run. I am aware of others who have run an m18 with an auto.
Post Posted: Tue Jan 31, 2017 1:55 pm
Hi Hillbilly2
What was wrong with my question about the M18a into an Auto Jimny ?
I was only really asking whether the auto and manual have same bell housing pattern or is the block different for a manual and auto .
Vehicle: Which one?
Post Posted: Tue Jan 31, 2017 4:59 pm
Lance1736 wrote:
Hi Hillbilly2
That's not Hillbilly referring to you, that is just Steve quoting him in his signature. Hillbilly was referring to Steve in another thread.
Post Posted: Tue Jan 31, 2017 5:38 pm
Ah- my signature strikes again with the newbies!
Yes it will bolt up.
I really can't stress how hot these autos run compared to the AW-4 used in the vitara. They run hot even with a g13bb at 110nm
Two cars with the same gearing and tyres on the same track will see the jimny auto up to 50 degrees hotter than the AW-4
Post Posted: Thu Feb 02, 2017 12:45 am
Ok thanks for the info . I guess Hillbilly strikes again .
Post Posted: Mon Feb 06, 2017 12:16 am
The auto seems to be more than a bit fragile - it will easily cook itself, if you do some steep (but a long way from seriously steep) trails and forget to shift to low range.
When it does cook, it's basically a chuck away job - find a s/hand box, as the cost of rebuilding it will likely be more than the car is worth.
Rgs, Michael
Users browsing this forum: No registered users and 70 guests
