It is currently Sun Aug 09, 2026 11:01 pm
Vehicle: 1991 1.3L JX sierra
Post Posted: Sat Mar 18, 2017 8:24 pm
Would the alternator in my 91 Suzuki sierra 1.3L jx be able to produce enough power to run a 392 watt light bat?
Post Posted: Sun Mar 19, 2017 2:59 am
I'm going to assume you mean a light bar - 392w from 12v is 30+ amps for the light bar - I don't remember the exact output on that alternator but it's not very high, so, I'm going to say NO, and then I'm going to ask what on earth do you need a 392w light bar for?
Post Posted: Sun Mar 19, 2017 7:43 am
X2. No the alternator won't be adequate The maximum output of a hot Sierra alternator is only about 35A. The EL/EF 110/110A alternator upgrade will probably be sufficient once revs are above idle.
Vehicle: Suzukiless these days..
Post Posted: Sun Mar 19, 2017 8:05 am
The Dictators going to be pissed.....stop giving useful information.
goddamitmyspacebarsbrokenagain
Post Posted: Sun Mar 19, 2017 2:13 pm
FWIW eBay lightbars wont consume anywhere near the power they say they will. I've bought several and at best they'l have similar power input to a brand name bar of that size, so up to 120w for a 20" bar and likely much less. I had a 24" bar that used a measly 40w, I think it was advertised as 180ish.
I recently bought a set of LED driving lights that were rated at 555w and were only 80w.
You can use this as leverage to get some money back or just return if you aren't happy.
I think it's worth spending the little bit extra and getting a lightbar with a fish eye style lens (4D or 5D ect), all my conventional reflector cone light bars have no distance where as my 20", 80w 4D light bar out does all my HID spotties (and LEDs) for distance.
Post Posted: Sun Mar 19, 2017 10:30 pm
This is quite interesting - I've been telling people that LED bars lack range because of the lack of a lens in front of the LED (you cannot shape the beam properly with just a reflector), but, I find it hard to believe that adding a fisheye lens will give it the range to out do a decent HID spotty.
What sort of HID spotty are we talking here?
Post Posted: Mon Mar 20, 2017 4:34 am
These, a few months back I gathered up all my lights and shone them off the veranda (across the paddock). There's Narva 175s, Narva 160/115s, Red ring eBay specials, KC Daylighter copies, old IPF.
I tried everything but the red ring lights (and leds, obviously) with 100w halogen and HID. Whilst the HID certainly was brighter it wasn't "smooth" like the halogen globes and I honestly preferred the halogen. It seemed as if the hid globes needed to go another few mm into the housing and the position of the ceramic tube needed to be changed (it caused a dark spot). The red ring lights were smooth but not as smooth as the LEDs.
The red ring eBay Hids were the best of the conventional lights. Sure, they're not a Lightforce product but the 4d light bar is cheaper anyway.
At 80w vs 55w the 4d light bar is more powerful but only it and the spot red ring light could reach the trees across the paddock and the light bar lit up 2-3x the area and that was brighter than the HID too. IMO it's much more effective at that range than the power increase indicates.
Some of the high end brand name leds use fish eye lenses, some don't. It doesn't seem to matter much in all the comparos.
Users browsing this forum: No registered users and 98 guests
