| g13bb Crank position sensor https://auszookers.com/forum/viewtopic.php?f=37&t=54032 |
| Author: | Bad Goat [ Mon Mar 20, 2017 5:34 am ] |
| Post subject: | g13bb Crank position sensor |
Did the g13bb in Jimny come with a crank position sensor? I ask because all of the g13bb motors in United States had one, but our version of the Jimny got the axe in 1996. When i look at G13bb oil pans on AU ebay they don't have a hole for the crank position sensor. |
| Author: | Gwagensteve [ Mon Mar 20, 2017 6:52 am ] |
| Post subject: | Re: g13bb Crank position sensor |
G13bb's don't have the crank position sensor. If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job |
| Author: | jdk81 [ Mon Mar 20, 2017 8:17 am ] |
Check megazip. They should list a sump with ckp sensor hole. I would look, but not at a pc atm. |
| Author: | MrRocky [ Mon Mar 20, 2017 10:46 am ] |
I think some spain built convertables run g13bb with crank sensors |
| Author: | Bad Goat [ Mon Mar 20, 2017 12:48 pm ] |
Gwagensteve wrote: G13bb's don't have the crank position sensor. If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job The 1.6 pans fit. But when i bolted it up it had clearance issues with the front axles. My Samurai is almost stock height, just a set of OME springs. Do your g13bb have a distributor? It doesn't seem like the cam position sensor alone would have enough resolution to do coil packs, even wasted spark. |
| Author: | Bad Goat [ Mon Mar 20, 2017 12:53 pm ] |
jdk81 wrote: Check megazip. They should list a sump with ckp sensor hole. I would look, but not at a pc atm. I've never seen megazip before. is it pretty reputable? |
| Author: | Gwagensteve [ Mon Mar 20, 2017 1:06 pm ] |
bb has a camshaft position sensor. Coil pack balenos have both cam and crank. Sounds like you're going to need to cut and shut a pan. |
| Author: | Bad Goat [ Tue Mar 21, 2017 1:28 am ] |
Gwagensteve wrote: bb has a camshaft position sensor. Coil pack balenos have both cam and crank. Sounds like you're going to need to cut and shut a pan. Maybe I'm a bit slow, but you're saying that g13bb have a cam position sensor, no crank, and coil packs? I have a modified pan. I've had it off twice now due to leaks, but I think I have it on leak free this time.... |
| Author: | Gwagensteve [ Tue Mar 21, 2017 5:50 am ] |
Correct. Although as has been pointed out it seems that some (all?) convertible jimny's, which were made by Santana in Spain, are g13bb's with both. Convertibles are rare here however. |
