It is currently Sun Aug 09, 2026 8:58 pm
Vehicle: Holden Drover '85 NT 1,3
Post Posted: Tue Mar 21, 2017 1:15 am
So noticed some pretty weird noises from the area of the timing belt on the project car - screeching and the like. I figured I would replace the belt and castors etc along with the waterpump as part of the makeover.
Removed the timing cover and it is clearly getting mangled by the crankshaft gear. A bit split in the cover and the plastic on the inside is badly worn with signs of heat damage. Suddenly the hole in the radiator and the slight ding in the bullbar are making sense! I reckon the front end has been impaled on something like a branch and the branch has pushed the front of the timing cover in, cracking it and causing the leading edge of the crack to rub against the crankshaft gear teeth.
Funnily enough - the damage was totally hidden when the cover was in place and you had to look really closely from the outside to detect it, but from the inside it looks totally trashed. The timing belt on the other hand looks brand new (but it went anyway).
I love this project - its part forensic detective and part Top Gear :)
Post Posted: Wed Mar 22, 2017 8:25 am
Post pics! Be interesting to see what the damage looks like
That's one of the things I enjoy about my cars, analytical thinking and finding the problems.. it's like a good brain game :)
Post Posted: Thu Mar 23, 2017 1:17 pm
Fitted the new cover yesterday and all looks set to go now. Here are some pics of the old cover before disassembly, damage is not really obvious from this angle ..
but once removed...
then inside you can see where the belt has been wearing away...
Post Posted: Thu Mar 23, 2017 1:23 pm
Not unusual.
Post Posted: Thu Mar 23, 2017 1:58 pm
What causes it Steve?
Post Posted: Thu Mar 23, 2017 3:45 pm
Movement in the belt, heat distortion, breakdown of the rubber grommets around the mounting screws, overtensioning the hold down bolts without the grommets in place- a few things really.
Post Posted: Thu Mar 23, 2017 10:06 pm
I've seen the plastic itself warp on mine before causing it to rub.
