| Author |
Message |
Bad Goat
Vehicle: 1988 US Samurai
 Posted: Mon Mar 20, 2017 5:34 am |
Did the g13bb in Jimny come with a crank position sensor? I ask because all of the g13bb motors in United States had one, but our version of the Jimny got the axe in 1996. When i look at G13bb oil pans on AU ebay they don't have a hole for the crank position sensor.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Mon Mar 20, 2017 6:52 am |
G13bb's don't have the crank position sensor.
If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Mon Mar 20, 2017 8:17 am |
Check megazip. They should list a sump with ckp sensor hole. I would look, but not at a pc atm.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Mon Mar 20, 2017 10:46 am |
I think some spain built convertables run g13bb with crank sensors
_________________ ...
Bad Goat
 Posted: Mon Mar 20, 2017 12:48 pm |
Gwagensteve wrote: G13bb's don't have the crank position sensor.
If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job The 1.6 pans fit. But when i bolted it up it had clearance issues with the front axles. My Samurai is almost stock height, just a set of OME springs. Do your g13bb have a distributor? It doesn't seem like the cam position sensor alone would have enough resolution to do coil packs, even wasted spark.
Bad Goat
 Posted: Mon Mar 20, 2017 12:53 pm |
jdk81 wrote: Check megazip. They should list a sump with ckp sensor hole. I would look, but not at a pc atm. I've never seen megazip before. is it pretty reputable?
Gwagensteve
 Posted: Mon Mar 20, 2017 1:06 pm |
bb has a camshaft position sensor. Coil pack balenos have both cam and crank.
Sounds like you're going to need to cut and shut a pan.
Bad Goat
 Posted: Tue Mar 21, 2017 1:28 am |
Gwagensteve wrote: bb has a camshaft position sensor. Coil pack balenos have both cam and crank.
Sounds like you're going to need to cut and shut a pan. Maybe I'm a bit slow, but you're saying that g13bb have a cam position sensor, no crank, and coil packs? I have a modified pan. I've had it off twice now due to leaks, but I think I have it on leak free this time....
Gwagensteve
 Posted: Tue Mar 21, 2017 5:50 am |
Correct. Although as has been pointed out it seems that some (all?) convertible jimny's, which were made by Santana in Spain, are g13bb's with both.
Convertibles are rare here however.
