It is currently Sun Aug 09, 2026 8:05 pm
Vehicle: SJ70 1993
Post Posted: Wed Mar 22, 2017 9:18 am
I been hitting the search bar for abit now cause im sure i have seen the list on here before but i cant seem to find it.
If someone finds it can you let me know what you entered to find it in the search?
If not what GV model rims fit wt sierra?
regards
Lock, Drop and roll
Post Posted: Wed Mar 22, 2017 10:23 am
All pre 2005 grand vitara rims will fit a sierra. (5/139.7 pcd, 108mm centre bore)
I used to run a set of XL7 alloys on my sierra. I think the offset between GV and WT sierra is pretty much the same too, I recall them being +5mm.
Only thing worth noting is a lot of tyres to suit 16" wheels are a much higher load rating than the equivalent size tyre on a 15" rim.
Vehicle: SJ70 1993
Post Posted: Wed Mar 22, 2017 12:53 pm
cheers jono
load rating = weight and less bagging?
Lock, Drop and roll
Post Posted: Wed Mar 22, 2017 1:08 pm
Yep.
Post Posted: Wed Mar 22, 2017 1:12 pm
http://auszookers.com/forum/viewtopic.p ... edy+offset
Post Posted: Wed Mar 22, 2017 1:13 pm
That's correct. The only sizes in a 16" rim I think are really worth running on a sierra are a 235/85/16 (31.7x9.25") or 255/85/16 (33.1x10") which are a narrow enough tyre you don't need much wheel offset, and can still keep good ground pressure.
Vehicle: SJ70 1993
Post Posted: Wed Mar 22, 2017 3:28 pm
Thanks atari. Found that now :)
Lock, Drop and roll
Post Posted: Sun Mar 26, 2017 10:50 pm
just for the hell of it, I would love to see a zook try on a set of Rolls rims.....
Users browsing this forum: No registered users and 41 guests
