It is currently Fri Aug 07, 2026 4:11 pm
Vehicle: Suzuki Jimny
Post Posted: Tue Jul 04, 2017 2:15 pm
Rear seats in the LWB are rubbish.. so what else fits?
Post Posted: Tue Jul 04, 2017 2:30 pm
Nothing or everything depending on what level of legality you want, and how much fabrication you're willing to do.
Consider too the layout of the vehicle and the position of the seats will have a lot to do with comfort. It's never ideal to be sitting on top of the rear axle
Post Posted: Tue Jul 04, 2017 3:07 pm
Wj seats look to work
Post Posted: Tue Jul 04, 2017 10:33 pm
Just take them out and plead ignorance to those who want to sponge a ride... worked for me.
Post Posted: Wed Jul 05, 2017 7:12 am
I often wondered whether SWB front seats would fit in the back of the LWB ?
Post Posted: Wed Jul 05, 2017 8:02 am
There's insufficient width between the wheelwells for two buckets. I recall it's less than 34"
The ideal seat would probably be a mastercraft/beard/prp US made suspension seat. They make rear benches for buggies and jeeps with the same manufacturing process as their race style front seats. However I think the minimum width for these is 36"
The mastercraft rear bench is cool but 40" wide.
Post Posted: Thu Jul 06, 2017 5:42 pm
41 inches 'twixt rear wells by my tape .... have to be close
Vehicle: sc100 se416 mightyboy
Post Posted: Sat Jul 08, 2017 11:53 pm
http://www.ebay.com.au/itm/SUZUKI-SJ410 ... 9#shpCntId
these would be pretty awesome I reckon...
Why make your Suzuki like a Vitara, Just get one.
Post Posted: Sun Jul 09, 2017 9:14 am
900mm wide full tilt
Post Posted: Sun Jul 09, 2017 10:33 am
The spacing between the wheel wells is 890mm (or 35") , just measured in on the trolley tug (so a 1991 widetrack) This matches my LWB, which only just fits an unmounted 35" tyres between the tubs. I'm not sure what's 41" wide between the tubs, but it's not a sierra.
Whilst that WJ seat looks awesome, there's some potential legal ramifications there - the seat mount must be strong enough to deal with the leverage the inertia reel belt provides. The stock seat mount wasn't designed for that load.
An engineer would need to be consulted to ensure the en result was legal.
Post Posted: Sun Jul 09, 2017 6:07 pm
Vitara ... I missed the bit about the LWB being a sierra
Post Posted: Mon Jul 10, 2017 7:08 am
Didn't think the high position of the seatbelt would be an engineer issue.
I would look to mount it on the existing frame. That's a pain!
Might look at re-doing the original seats with thicker foam and some side padding
Post Posted: Mon Jul 10, 2017 8:05 am
Sadly yes. The factory floor mounts have be strong enough to retain the seat only. The factory lap seatbelt mounts don't see very much leverage, however with an integrated intertia reel belt, the weight of two passengers (at multiple g force) is trying to pull the seat up out of the floor- not a direction the factory floor mounts were designed to counter. The seatbelt can't save someone when it isn't attached to the car.
I'd be interested if there is a maximum weight limit for those jeep seats. Manufacturers often to this to limit liability if the seat or mounts break.
Vehicle: 89 suzuki sierra
Post Posted: Sun Jul 16, 2017 6:07 pm
I have some measurements to take but 3rd row seats from an xc90 might work they are on a frame complete, plenty of mounting points to attach to car, would need however to get belt stalks to suit which wouldn't be easy but anything is possible
Post Posted: Thu Aug 03, 2017 8:14 pm
Sounds interesting, any luck?
Users browsing this forum: No registered users and 35 guests
