It is currently Sat Oct 24, 2026 12:24 am
Post Posted: Sat Oct 31, 2009 4:09 pm
Got a 97 coily and i've filled the rear diff with mud, i noticed a lot of noise all of a sudden going down the freeway kind of like a stuffed bearing noise i pulled over immediately and dropped the oil to have a look and it was muddy as. There were no chunks of metal only some fine metallic paiste stuck to the magnet it kind of resembelled graphite grease, i had the car put on a truck and taken home i just want abit if an idea of what i might be up for ie just bearings or full rebuild? or if anyone else has done this themselves and what did they have to do.
thanks Richo
Post Posted: Sat Oct 31, 2009 4:40 pm
Sounds like a full rebuild time. You might be better tracking down a second hand one. Rebuild would cost between $300-500
Post Posted: Sat Oct 31, 2009 4:42 pm
flush it with some diesel and stick new oil in it, it will either be ok or you were going to replace t anyway :)
also check your bearings as well, grit will stuff them up pretty good
Vehicle: MY2019 Jimny
Post Posted: Sat Oct 31, 2009 5:04 pm
While you have the centre out, install a good breather!
Post Posted: Sun Nov 01, 2009 2:02 am
weaves can do a full center bearing kit for like $60...
Post Posted: Sun Nov 01, 2009 5:30 pm
$60! thats great, how can i contact Weaves?
Post Posted: Sun Nov 01, 2009 5:46 pm
pm via forum should work.
[URL=http://img406.imageshack.us/i/samuraifsmpdf.g
Users browsing this forum: No registered users and 72 guests
