It is currently Sat Oct 24, 2026 7:13 pm
Vehicle: '94 Stockman Trayback
Post Posted: Mon Feb 01, 2010 4:19 pm
thanks now sorted
Post Posted: Mon Feb 01, 2010 5:08 pm
thanks now sorted
Post Posted: Mon Feb 01, 2010 6:50 pm
A 5 speed box would be good, lots of guys have done this with no dramas and it worked well droping hiway rpms but 5 speed gearboxes for 1 litre engines are hard to find. You should be able to find a good 4 speed as lots of people have conveted to 1300 5speed so they are around. This will be your cheapest option, what year is your car as there are two different 4 speeds in the 1 litres, a small gearbox which is similar in size to an LJ gearbox and a large gearbox which is similar in size to a 5 speed sierra box, they bolt in differently.
Post Posted: Mon Feb 01, 2010 8:23 pm
thanks now sorted
Post Posted: Mon Feb 01, 2010 10:49 pm
pm zookster666 he was trying to sell a 1l 5spd box not long ago, he might still have it.
Post Posted: Mon Feb 01, 2010 11:02 pm
thanks now sorted
Post Posted: Tue Feb 02, 2010 1:45 am
cause yours is the later model maruti, not the sierra 1ltr the tailshaft yoke should be the same as a 5spd box meaning you should be able to swap the guts out of a sierra 5spd straight int your 4spd housing as they are the same except for the bolt pattern on the bellhousing. This was the case with 2 of my previous rigs but they were both 96 maruti lwb.
Post Posted: Tue Feb 02, 2010 1:47 am
yep. im the lucky bugger that brought it. it's not just a straight forward bolt up but I don't think it will be too much work.
hey 2stroker the 2 different 4 speeds that you talk of... are they just mounted differently at the gearbox cross member or is the bell housing mounting different too?
Users browsing this forum: No registered users and 110 guests
