It is currently Sun Oct 25, 2026 2:14 am
Post Posted: Fri May 07, 2010 10:48 am
Does anyone know where to get the banjo bolt with copper washers to suit the vitara p/s box high pressure line. Brisbane area would be good
Also does anyone know what sort of rubber hose I can use for the low pressure hose from the box to the resovoir does it have to be a steel line like the stock one?
Zookster
Post Posted: Fri May 07, 2010 10:54 am
go to enzed. they will have everything you need.
the low pressure line can be just low pressure hose (SAE R6 or R7). but if it is a long run it would be better (and cheaper) to run a length of steel tube (called bundy tube)
Post Posted: Fri May 07, 2010 11:04 am
Thanks for the fast reply bud will try them tomorrow
Users browsing this forum: No registered users and 108 guests
