It is currently Sun Oct 18, 2026 6:44 pm
Post Posted: Thu Jul 26, 2007 1:07 am
i want to modify the rear a arm on the vitara to allow more travel for my new shocks. anyone have any ideas or know of someone that has modified it similar to the calmin heim joint? or thaqt could make one up?
these are some pics sent to me on a design
Post Posted: Thu Jul 26, 2007 1:33 am
That's a fairly easy mod for any shop to do or a lot of guys on here , but not legal as rose,heim joints are not legal unless pacifically engineered for that application , also the wear and tear on that particuliar joint as it sees all the suspension movement may cause premature failure , rose,heim joints don't like sideways movement and maybe another type of joint would be more suitable , I'll post a drawing of what I mean , Cheers Paul.
Post Posted: Thu Jul 26, 2007 2:17 am
that would be great thanks. would it be a better idea to somehow make a spacer from the top mount on the diff to the balljoint on the original arm???
Post Posted: Thu Jul 26, 2007 3:13 am
This is the path I am going to go down. See:
http://bbs.zuwharrie.com/content/topic,63310.0.html
and:
http://www.outerlimits4x4.com/phpBB2/vi ... 0d989c7c42
There are some mixed thoughts on the drop bracket, but overall, it seems like a good idea. On the front, I was going to drop the diff 30mm, and space the springs and strut down by the same amount.
I have talked to just_cruizin about the strut spacers and the rear spacer, so we'll see if he comes up with a solution. His body lift kit I picked up today is awesome, so I know he'll do a good job...
Rod W
92 Vitara JLX Wagon
Post Posted: Thu Jul 26, 2007 3:20 am
Don't know where your at but Glen Dobbin makes these swivel joints , much stronger than a rose,heim joint. You could weld it to your original or new top diff plate and then cut the top arm and weld in the tube , this will be tough as nails and will give you all the movement you will ever need , you grease it up and lock off the nuts and you will never have to touch it again or until the next mod , this is not the only option , hope this helps , Cheers Paul.
Post Posted: Thu Jul 26, 2007 10:16 am
or you could try this if you really wanted to get creative
Post Posted: Thu Jul 26, 2007 4:43 pm
thanks for the info and pics paul, looks like it could be a way to go. im in qld not far from brisbane. with the design u posted do u have any measurements or breakdown of all parts???? as well instead of the brass bushings would it be possible to use something like a swivel hub bearing???? thanks Rob
Post Posted: Fri Jul 27, 2007 2:52 am
or you could do it on the cheap like that!
Suzuki's - It's not the size,
It's how you use th
Post Posted: Fri Jul 27, 2007 7:52 pm
Bearings arn't really suitable as you need a sealed unit to live iin that evironment so if you used tapered bearings you would need seals , even flat bearings would still fill with crap and moisture , the bronze bearing needs little lubrication and is ideal in this situation , not saying there isn't any other way but it's probably the best. What sort of dollars where you thinking of spending , Cheers Paul.
Post Posted: Thu Aug 02, 2007 12:49 am
i was expecting somewhere from 150 - 300. not sure what its worth in parts and labour to fab up. and toying with the idea of making a spacer up for the balljoint to keep it simple. just not good with the engineering side
Post Posted: Thu Aug 02, 2007 6:37 pm
Is that a tow bar and ball?? 8O 8O
84 lwb sierra, 30x9.5, 2 inch lift
http://www.aus
Vehicle: 1994 Hard Top Sierra
Post Posted: Fri Aug 03, 2007 1:33 am
certainly looks like it :wink:
Jason
Navigator for Team Casper
Post Posted: Fri Aug 03, 2007 2:25 am
sigh, dodgy is always funny :lol:
[img]http://www.auszookers.com/modules/coppermine/
Mate you would probably get one of glen for that price if your interested , Cheers Paul
Vehicle: 75 Cruiser
Post Posted: Fri Aug 03, 2007 10:49 am
looks like the whole thing has been at the bottom of the ocean for a while :?
Post Posted: Tue Aug 07, 2007 6:45 pm
would be interested. let me know. cheers rob
Post Posted: Thu Aug 09, 2007 11:41 pm
I'm going to see glen next week , I will get a exact price from him and let you know , are you able to weld up the mounts for this , Cheers Paul.
Post Posted: Fri Aug 10, 2007 2:11 pm
to date my welding skills are limited to making a set of sliders. but i do have a mate that would be able to weld it up. thanks for the help
Post Posted: Thu Aug 23, 2007 10:42 pm
Wasn't there last time I went past , going tommorrow to see him , let you know , Cheers Paul.
Post Posted: Fri Aug 24, 2007 1:27 am
thanks mate. much appreciated
Post Posted: Fri Aug 24, 2007 7:02 pm
Mate , $320 + postage so would be $350 tops. PM me your number and I,ll give you a call if your stiill interested , Cheers Paul.
Users browsing this forum: No registered users and 284 guests
