It is currently Wed Oct 28, 2026 10:27 am
Post Posted: Sun Jun 13, 2010 2:18 am
i done the rear pinion seal in my zook only to see
that its leaking again not long after..... my question is
what would prematurely flog out the seal. the diff does
have some back lash could this be the cause ????
cheers
Post Posted: Sun Jun 13, 2010 3:40 am
I have the same problem...
I'm tempted to try some stop leak or something, but not sure if that will effect the diff oil.
I'd put money on the cause being a worn surface of the pinion flange where the seal runs. The only fix for this would be to machine the surface down to accept a speedy sleeve.
Post Posted: Sun Jun 13, 2010 4:05 am
If the sealing area is a common size then you don't need to machine to accept the speedi sleeve
Post Posted: Sun Jun 13, 2010 4:12 am
It's possible the flange nut wasn't done up properly and there is play in the bearing. Otherwise as Fatzook suggested
Post Posted: Sun Jun 13, 2010 4:30 am
When has suzuki EVER use common sizes :roll: :D
Post Posted: Sun Jun 13, 2010 5:37 am
yeah mine is just replaced and leaking also. like the day after i did it... the nut is as tight as it was before, and there is no more play then normal.... im thinking maybe worn bearings on the pinion.....
Post Posted: Sun Jun 13, 2010 6:13 am
when it leaked originaly did you change the pinion bearings or just chuck a seal in?
Post Posted: Sun Jun 13, 2010 6:17 am
I have new bearings in carrier and pinion, new crush tube and seal. Still leaks :?
Post Posted: Sun Jun 13, 2010 6:18 am
why not just chuck a second hand front flange on?....they wear a heap less.
Post Posted: Sun Jun 13, 2010 6:28 am
I'm running vitara front flanges off low km imports. they looked miles better than the sierra ones.
Post Posted: Sun Jun 13, 2010 10:34 am
did the flages go on easy or did you have to tap them on quite hard?
Post Posted: Sun Jun 13, 2010 10:51 am
I didn't do them myself, but I know that the guy who did them is not the 'get a bigger hammer' type of guy.
What difference would this make anyway Joe?
Post Posted: Sun Jun 13, 2010 11:19 am
there are two types of spline. one is a triangular shape wich goes down to a point on the end, the other is more of a square cut. mix the two together and you can get oil comming up the splines.
Post Posted: Sun Jun 13, 2010 12:16 pm
Cool. Mine is definately coming from the seal. Might just speedy sleeve it anyway.
Post Posted: Sun Jun 13, 2010 1:08 pm
cheers for the help guys i might go the sleave aswell
Users browsing this forum: Google [Bot] and 439 guests
