It is currently Tue Oct 27, 2026 9:07 pm
Post Posted: Sun Jul 11, 2010 8:05 am
my 95 sierra has a small crack in the windscreen frame just near the washer sprayer thing just wondering if there is any way of covering this up/bracing over the top of it with out welding & re-painting it the crack is about 20mm long
Vehicle: 4wd
Post Posted: Sun Jul 11, 2010 8:17 am
Is it near the jet or near the wiper arm?
Watch out or you'll get sued.
Post Posted: Sun Jul 11, 2010 8:18 am
get a small drill bit and drill out the ends of the crack that should stop it getting any bigger and fit some ally checker plate over it
Post Posted: Sun Jul 11, 2010 8:19 am
honks I found that the metal is as thin as. I pulled out the frame and welded it up. Very thin, weld grind, weld grind, weld grind...The crack is from the panel flexing when the wipers are on. Check the wiper pole and stick some lube on it . Mine was a bit rusted and seized.
You may be able to cut some alloy plate and drill a hole the size of the pole and stick it on with sika flex. A piece right across the front might look ok :roll:
98 GV
Post Posted: Sun Jul 11, 2010 8:52 am
crack is near the jet might put some plate over it or something like that just don't want to leave it to long and get it full of rust
Post Posted: Sun Jul 11, 2010 9:01 am
when putting the plate on try not to put any weight onto the frame exspecially the corner were the wipers are. the bottom panel is very weak and doesnt take much to make it flex. ive craked two (2) windscreen from putting little bit of weight to the fram and playing with the wipers, not very happy that i got to go out and get a third windscreen
Users browsing this forum: No registered users and 426 guests
