It is currently Wed Oct 28, 2026 10:37 pm
Post Posted: Wed Jul 21, 2010 5:07 am
are vitara and sierra centres compatable? i have a vitara available for parts and wondered if i could swap centres?
front one will fit, but its alloy so you dont want to do it.
Post Posted: Wed Jul 21, 2010 5:11 am
so the centres are not worth swapping? not even crown and pinion
Post Posted: Wed Jul 21, 2010 5:14 am
crown and pinions into sierra centres are a very common swap for lower gearing. but again only the front one is any use for this
Post Posted: Wed Jul 21, 2010 5:23 am
well thats no help, what do they use as rear centre then?
Post Posted: Wed Jul 21, 2010 5:26 am
a front one
i.e the front ones from a vit can be used in a sierra front and rear
Post Posted: Wed Jul 21, 2010 5:29 am
oh now i get you i thought that only fronts would work. do you happen to know what ratio they are?
Post Posted: Wed Jul 21, 2010 5:33 am
depends on the model of vitara.
most are 5.1:1
ratios for a vitara i believe 4.3 4.6 4.8 5.1
sierra you can get 3.7 3.9 4.1
aftermarket you can get 5.3
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Jul 21, 2010 5:34 am
5.1 usually
apparently you need to do some creative engineering to stop the pins that go into the spider gears from sliding out and breaking stuff. like hammer time or tack weld them in place.
Vehicle: Nissan
Post Posted: Wed Jul 21, 2010 5:35 am
most are 5.1:1
how do you tell what ratio you have without counting the teeth?
as in year model etc???
Pearce-toff Racing
Vehicle: Nissan
Post Posted: Wed Jul 21, 2010 5:36 am
neofitou wrote:
5.1 usually
no just buy this here: http://www.lowrangeoffroad.com/suzuki/s ... -cans.html
Pearce-toff Racing
Post Posted: Wed Jul 21, 2010 5:39 am
this is from what i know so it may not be 100%
4.3s came in GV
4.6 came in vitara 1.6 carby 3 spd autos
4.8 came in 2.0 v6 vits
3.7 in the wide track 1.3
3.9 in the narrow track 1.3
4.1 came in the jimny i think but also the wide track maruti
5.1 came in all vits not covered above
Post Posted: Wed Jul 21, 2010 5:51 am
alex wrote:
neofitou wrote:
5.1 usually
no you need do nothing special.....as i have said before you get some thick industrial o-rings from a bearing joint and seat them between the ring gear and centre.....job done and they will never move (and it looks alot neater and is easily removed.)
note you don't need to do this if running air lockers.
Post Posted: Wed Jul 21, 2010 6:29 am
I like that idea
Post Posted: Wed Jul 21, 2010 7:04 am
4.3s came in GV
4.6 came in vitara 1.6 carby 3 spd autos And 1.6EFI auto X-90
3.9 in the narrow track 1.3 And coily sierra
4.1 came in the jimny i think but also the wide track maruti I think the jimny is slightly different. like 4.09 :?
Post Posted: Wed Jul 21, 2010 7:19 am
did coilys come out 3.9?
Post Posted: Wed Jul 21, 2010 11:38 am
All coilys are 3.9.
Post Posted: Wed Jul 21, 2010 12:54 pm
4.3s came in GV
3.9 in the narrow track 1.3 And coily sierra And rare 88' widetrack including lwb wt
4.09 Jimny
4.1 lwb wide track maruti
Users browsing this forum: Google [Bot] and 299 guests
