It is currently Mon Oct 19, 2026 3:17 am
Post Posted: Thu Dec 27, 2007 4:55 pm
Hey everyone im new to the whole suzuki wheelin i just gave ARB a call to talk about a OME suspension lift for my 91 swb jlx vitara the fella informed me that they only do 1inch suspension lifts for them? is this true? if so how come iv seen other vitara with 3inch ome lift? he also stated that a body lift of any kind was ilegal is this also true? im in NSW if this helps cheers.
Post Posted: Thu Dec 27, 2007 5:11 pm
I think Calmini are the only ones that do a 3" lift, I guess some people might have OME springs and spacers to make 3" and most people are using OME front struts with their lift as they have the longest extended length
pretty sure bodylifts are legal in all states but check with your DOT, RTA etc. to find out what needs to be done for approval
Post Posted: Fri Dec 28, 2007 1:30 am
You will probably be required to have an engineer approve the body lift. But don't believe everything the salesmen tells you. Calmini do a good kit but a little stiff apparently, go look at the XC90 build up on the 4wd monthly website and you see how they fixed this.
Users browsing this forum: No registered users and 204 guests
