It is currently Fri Oct 30, 2026 3:18 am
Post Posted: Mon Aug 30, 2010 7:12 am
Anyone have any Coil Spring spacers there running in their Coilys?
Just wondering the best place to buy them, as my mate just fitted a set to his surf, sounds a cheap lift.
I found these on Ebay, Spring Spacer
Is it a relativatly easy procedure installing them, I all ready have a 2" spring lift.
Cheers.
Post Posted: Mon Aug 30, 2010 10:51 am
I would not use spacers for a cheap lift, I have only used them to level out the ride in my car. With the extra weight of my winch, bar and 2nd battery it sagged alot in the front.
Due to the way the suspension is set up in the front the 15mm spacer raises the vehicle by 30mm.
This only applies to ifs suspension. You will need the same spacer all around if yours is a coily.
Get some ratchet spanners, they will make taking the nuts off / putting them on the strut towers a lot faster.
Post Posted: Mon Aug 30, 2010 11:40 am
yeah i am with ridge. i have spacers to make myzook sit flat.
Post Posted: Mon Aug 30, 2010 1:31 pm
most people use them to lift a car, its not want its meant for but works perfectly fine in my vitara. i found it relativly easy to fit. make sure your car can handle bigger than a 50mm lift thou and make sure u get shocks to suit.
Post Posted: Wed Sep 01, 2010 2:12 am
If you're already lifted 2" (springs?) it will be a tight fit getting them in, but nothing too bad. Have just done the same to my IFS Vit to level out F/R.
PM bruce on here, he manufactures them and sells them nice and cheap.
Post Posted: Wed Sep 01, 2010 6:07 am
Quoting somone else here, but:
You're supposed to fix the problem, not just treat the symptoms.
If your front end sags, get stiffer springs.. Don't just pack a spacer in there
And a mate of mine put 1.5" Coil Spacers in his 4dr Vit a few months back, he's had no problems as yet
I helped fit them, front wasn't too bad.. And the rear was absolute cake
Post Posted: Wed Sep 01, 2010 6:42 am
:P Coil spacer's with out longer shock's snap's bottom shoky bolt's!!!
Jimny.. customer couldn't understand why warranty didn't cover it.. :roll:
Post Posted: Wed Sep 01, 2010 7:59 am
Uhh true true, thanks. Yeahh, my front sags a little due to the whinch and bar, so i'll put smaller ones in the back to level it out.
Users browsing this forum: Google [Bot] and 334 guests
