It is currently Fri Oct 30, 2026 12:17 am
Post Posted: Wed Sep 08, 2010 1:13 pm
Just curious as to how a hard top is mounted to sierras?
How hard is it to mount a soft top to a factory hard top and vice versa?
Post Posted: Wed Sep 08, 2010 2:29 pm
mounting a soft top to a tin top requires a full body swap, unless you just want to drape it over the tin top like a car cover?
the fiberglass hard tops have a few different over center latches & clips to hold down the 2 sections.
Post Posted: Thu Sep 09, 2010 7:38 am
By hard top i mean fiberglass.
Can you fit a soft top to a sierra which was factory fiberglass roof without mods? or will you need to drill the body for the studs?
Post Posted: Thu Sep 09, 2010 1:18 pm
You will need studs for back tub sides, and front window, special studs for tray door, a Front window channel(if it doesnt have one) and rear softop support bar
Post Posted: Thu Sep 09, 2010 1:29 pm
And the rope tracks that run down the back of the b-pillar.
Post Posted: Thu Sep 09, 2010 1:54 pm
Ah yes!
Post Posted: Thu Sep 09, 2010 2:01 pm
Damn, so much work just for a soft top.
Post Posted: Thu Sep 09, 2010 2:09 pm
How hard is just the front half of the hard top to a soft top?
Hoping to mix that with a fast back soft top?
Users browsing this forum: Google [Bot] and 132 guests
