It is currently Fri Oct 30, 2026 1:28 pm
Post Posted: Thu Sep 16, 2010 11:01 am
Im looking to upgrade to a larger radiator for a 92 vit.
im pretty sure they come in two heights and i have the shorter one. Can anyone tell me if the longer one bolts in?
Also is a GV bigger? If so would that fit?
Post Posted: Thu Sep 16, 2010 11:28 am
the radiator that came with your car is ample , if you are having overheating issues i would be looking at the viscous hub fan , blocked radiator (cooling fins and core) , thermostat , or water leaks or head gasket issues.
ive done many cars pumping out over double factory hp with stock radiators
Post Posted: Thu Sep 16, 2010 11:30 am
x2.
Changine cooling system components leads to complications, and further expense.
If it aint broke, don't fix it :D
Post Posted: Thu Sep 16, 2010 11:43 am
no worries, its actually getting a toyota 4agze engine conversion which will produce a fair bit more heat but if you say its ample ill stick with it :)
Post Posted: Thu Sep 16, 2010 11:45 am
If your radiator is clean, and in good condition it should be fine. :wink:
Users browsing this forum: No registered users and 401 guests
