It is currently Mon Nov 02, 2026 12:07 pm
Post Posted: Sun Sep 26, 2010 8:55 am
I bought a h20a with 4 speed auto not long ago
Now i was told when i bought it that it had upgraded bands or somethng like that done to it, it shifts firmly and doesn't slip or have any other problems
Now the problem when cruising along at about 90-100kph in overdrive and come to an incline or accelerate enough for it to kick back from over drive it makes a rattling noise (sounds kind of like an exhaust heat shield rattle)
and lasts for all of 2 seconds max. Like i said other than this noise the gearbox is great.
does anyone have any idea what it could be?
inbits :cheers:
Post Posted: Mon Sep 27, 2010 10:55 pm
Anyone?
Post Posted: Mon Sep 27, 2010 11:53 pm
Checked your exhaust?
Post Posted: Tue Sep 28, 2010 2:42 am
Yeah I have been right over it it only does it wen kicking back from o/d
Post Posted: Tue Sep 28, 2010 3:27 am
Have you tried hitting the cat?
Post Posted: Tue Sep 28, 2010 8:35 am
No I haven't I will try that but I thought that if it were the exhaust then it would do it Alot more than just when it kicks back from o/d
Post Posted: Tue Sep 28, 2010 8:39 am
Poor kitty.. 8O
That also have a bracket on either side to hold the exhaust firm, it's at the bell housing, 2 14mm headed bolt's & a bent bracket, thay put out a strange noise when loose..... so do cat's..
Post Posted: Wed Sep 29, 2010 7:36 am
Poor kitty.. 8O
cheers ill check that when the drive way drys :D
Post Posted: Fri Oct 08, 2010 9:46 pm
Last night i went for a bit of a mud run, while trying to get up muddy clay hills etc reving the car once id back off the engine would stall while still in drive
then i noticed that it wont start in neutral only park could these problems be linked to this funny noise?
it also has no problem starting after stalling
thanks inbits
Users browsing this forum: Google [Bot], Gwagensteve and 459 guests
