It is currently Sun Nov 01, 2026 3:39 pm
Post Posted: Sat Oct 16, 2010 11:03 pm
:( C Could anyone please help me with a problem with earth leakage, I have fitted a falcon alternator, an electric fan and since then have a problem with the battery consistently going flat whilst the suzi sits. I may mention that it has a new battery 490 cca so much bigger than would normally be required. I thought that maybe the fan was causing it but what did show up the other night was that as I was coming home I turned my headlights on and the voltage guage showed a power drain that dragged the reading down to about 8 volts. :oops:
Post Posted: Sat Oct 16, 2010 11:17 pm
Sounds like the alternator is cactus, voltage regulator most probably.
Post Posted: Sat Oct 16, 2010 11:39 pm
I thought it may be but had it checked and it appears to be OK, but I will have it done again, by the way thanks for the answer.
growing old is nature, growing up is choice.
Post Posted: Sat Oct 16, 2010 11:50 pm
Itas a very easy check, if you have a multimeter, even a cheap one is a must have item in ya tool box.
Set it to volts, check battery voltage, start motor, and see what happens, if its a good system, at around fast idle you should have 14 or so volts, mine maxs out at 14.7v by my meter, the battery is new, holds 13.1v.
Post Posted: Sun Oct 17, 2010 12:19 am
I have tested the unit with a multimeter that shows 13+volts that is why I thought all was ok, but still the jigger flattens batteries.
Post Posted: Sun Oct 17, 2010 12:40 am
You want to test current draw from the battery. Using muktimeter set to amps. Disconnect earth lead on the battery and connect one lead,from the multimetre to the terminal on the battery and the other to the disconnected lead.
Let me know on the reading
An alternator can still charge and also drain the battery when not running..
Post Posted: Sun Oct 17, 2010 12:42 am
Sounds to me like you have an accessory that is not turning off when your ignition is off.
Have you got a butt-load of extra wires cabled to your +ve battery terminal?
Post Posted: Sun Oct 17, 2010 2:09 am
89-tintop the current draw a t negative terminal is very slight approx 2 amps but I do have an stand by radio fitted so the current draw I would think is not too radical. I do have a few fittings to the +ve eg: driving lights radio relay for radiator fan and the radiator fan.
Vehicle: 1987 sierra tray back buggy
Post Posted: Sun Oct 17, 2010 2:23 am
2 amps is huge if there is nothing on the strand by radio should not be drawing anything above milliamps.
Post Posted: Sun Oct 17, 2010 7:19 am
2 amps is huge mate.. Would discharge a battery overnight.
Disconnect some I'd accessories you have added lately while the multimetre is connected like I said before. eventually something that disconnect will drop the readout on ther multimetre to 0 or 0.02 it something like that is acceptable.
One you get it to drop let me know what it drops to.
Post Posted: Sun Oct 17, 2010 8:52 am
:D Have removed falcon alternator refitted original. No problem so far must have been a problem with the falcon alternator, will replace it in the near future and see what happens from there.. Thank you all for your suggestions and help. May the auszookers site rule forever. :woohoo:
Post Posted: Sun Oct 17, 2010 9:01 am
Once removed what did the multimetre readout drop to?
Just curious..
Users browsing this forum: Google [Bot] and 182 guests
