It is currently Sun Nov 01, 2026 10:07 pm
Post new topic Reply to topic  [ 115 posts ]  Go to page Previous  1, 2, 3, 4
Vehicle: 2004 SQ625 GV
Post Posted: Fri Sep 17, 2010 8:13 am
I run Z172 filters on both Gv's and had not had any problem with them. Running 20w40 shell mineral oil. I try to steer clear of any oils with addatives they seem to gunk up the engine.
Just went and checked the Z172 filter from the last oil change.There is a valve. if you look into the bottom of the filter it will look straight back at you.
Post Posted: Fri Sep 17, 2010 8:52 am
steak_knife wrote:
Chop wrote:
Well my understanding is that suzuki owns suzuki, but they arent all made in japan :wink:
India ..suzuki Alto's..
& the Gypsy!!!! :P :P :P :P :P :P :P :P :P :P
Some swifts are made there too, i think the 2 door but they dont come here.
Post Posted: Fri Sep 17, 2010 9:14 am
8O Thank god is only the 2 door's.. 8O
I do like the look of em tho, I asked Suzuki if thay would bring one in for me, prick's wouldn't do it tho.. :cry:
i've also asked em to give me a 3 door Gv or a Jim to race to.. :roll:
Same response!!!! :lol:
Post Posted: Fri Sep 17, 2010 9:31 am
Want me to ask for ya, my cousin owns Mayfair Suzuki. :wink:
SS
Post Posted: Fri Sep 17, 2010 9:39 am
MacBear wrote:
With a bloody long timing chain that is very expensive to change.
There is not one "bloody long" timing chain its more like four well one is for the oil pump....
And they are not that expensive to replace....that is unless you cant do it yourself :wink:
Post Posted: Fri Sep 17, 2010 9:41 am
ask him to start importing maruti's again. i would buy one. :wink:
Post Posted: Fri Sep 17, 2010 10:21 am
8O Single???? :P
Post Posted: Fri Sep 17, 2010 10:23 am
have asked several time's, thay say it's a huge pain in the butt getting car's out of india..
and thay know what we'll do to em while still in warranty!! :lol: :lol:
Post Posted: Fri Sep 17, 2010 10:32 am
do you mean things like a warranty clam for a new roof because the car fell on it. :lol:
Post Posted: Fri Sep 17, 2010 10:34 am
That & diff's cause we have 1.6's in front of em.. :P
Post Posted: Fri Sep 17, 2010 10:51 am
steak_knife wrote:
zukmeista wrote:
steak_knife wrote:
zukmeista wrote:
Slightly off-topic I know, but the other day when I was topping up the oil I noticed quite a bit of gunk under the rocker cover. What is the best way to get rid of this?
Oil flush...
What and where?
Oil flush, in your eng..
http://www.nulon.com.au/products/Engine_Oil_Flush/
come's with instruction's on the back O the botbot!! :P
x 34513450984509731431908234589234578902374523890457
I was given a carton of them a few years ago from a mate who worked in a Nissan Stealership, I used my last one today... I'll have to see if I can get another box of them.
I always flush my engines, my old pootrol with more than 300,000kms on it would just start carbon up the oil at 7,000. when the head came off the numerous times the internals looked spotless & I my Vitara is the same.
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Sep 17, 2010 11:08 am
I might give this stuff a go. My car has done 230K now and wouldn't hurt to try.
My car runs LPG now which means the oil should stay cleaner looking for longer, but the three changes i've done so far the oil is as dark as petrol after 5000 kms. An oil flush might be the answer
Post Posted: Fri Sep 17, 2010 11:12 am
without stripping then engine it will always be there, colour isnt everything
Post Posted: Fri Sep 17, 2010 11:14 am
The 2 door is Hungarian made.
Post Posted: Fri Sep 17, 2010 12:57 pm
I can't believe India sells Gypsies new for AU$14000. You could fit 3 in a 60ft shipping container and get them sent here for $1K a car.
I'd pay $15000 (if I had it) for a brand spanking new Sierra (Gypsy) in a flash - if I was wise enough to have bought a Sierra when I was 16yo (and kept it), i'd be wiping my arse with golden squares of toilet paper by now :cheers:
Vehicle: Jeep
Post Posted: Fri Sep 17, 2010 1:43 pm
Someone once put a pic up of the timing chain in the GV V6, and it went up and down a few times in the engine, it almost looked like the out line of a hand, and it was just one continuous chain... and from what i was told, to change that timing chain, one needs to remove the engine to do it, hence the expense of getting it done, at least a couple of grand... but if you have info that says, no it isnt that expensive, then please, share this info ! :wink: :D
Post Posted: Fri Sep 17, 2010 1:50 pm
Post Posted: Fri Sep 17, 2010 1:51 pm
i see 4 chains.
Vehicle: Jeep
Post Posted: Fri Sep 17, 2010 2:22 pm
i see 4 chains.
Well there you go, there is more than 1, thanks for the pics... i can see 3... :roll: :wink: :lol:
Post Posted: Fri Sep 17, 2010 2:25 pm
there are 4 chains, 3 would be "timing chains" & i guess the bottom one is for the oil pump?
Post Posted: Fri Sep 17, 2010 9:58 pm
Correct - and the timing chains CAN be changed with the engine in the vehicle, but it's easier to take it out and do them outside. The oil pump chain rarely gives trouble.
Post Posted: Fri Sep 17, 2010 10:20 pm
still looks like stupid idea and a major pain in the arse.
Post Posted: Fri Sep 17, 2010 10:29 pm
That ting there is 20 billion time's eayer to work on then zd30 shit box.
in theory thay shouldn't ever need replacing, but for a slight oil feed & ratchet problem thay get noisy & wear..
Post Posted: Tue Oct 19, 2010 6:24 am
Heres an oil analogy for you all
Normally I run Motul turbolite 10w40 oil in the vit, every 10k I change it, life goes on
last time round I used Motul power 15w50, thought not a lot of it, bit noisier but oh well
last few weeks the vit has been pinging quite a bit, not changed anything that would effect that so thought I better have a look, starting with changing the oil cause it was almost due and ive seen older swifts do a similar thing
oil changed and what do you know, no more pinging :wink:
Vehicle: Jeep
Post Posted: Tue Oct 19, 2010 2:05 pm
Wow 8O
Well that is very interesting....
Users browsing this forum: No registered users and 61 guests
