It is currently Sat Oct 31, 2026 2:49 pm
Post Posted: Sat Nov 13, 2010 10:23 am
Hi all, 2 questions if you dont mind :)
1. Do you think the stock front metal bar would handle mounting a winch to it (and using the winch of course)?
2. Whats the minimum load winch you think i could use on a sierra? Ive found some 4000lbs and 6000lbs winchs.
Cheers Mitch
Vehicle: jimny
Post Posted: Sat Nov 13, 2010 7:19 pm
The front bar is flimsy crap so don't mount a winch to it. My lwb weighs 1280kg times that 2.2 and that would be a start on the size winch in pounds, I reckon 4000 minimum. Sounds like you need to do some more research
Post Posted: Sat Nov 13, 2010 7:26 pm
As eldo said the bumper is crap and is only good for holding the indicators.
I would say a 6000lb winch would be the bare minimum and wouldn't expect it to last for long....
I currently run a 9500lb chinese lowmount but will soon be upgrading to a Warn hi-mount.
Post Posted: Sat Nov 13, 2010 9:36 pm
Ohk thanks for the replys, was just going to chuck the winch on the front temporarily until i get some sort of bars up front.
Maybe ill beef it up to the 8000, 9500lb winch then
Post Posted: Sat Nov 13, 2010 10:02 pm
http://auszookers.com/index.php?name=Fo ... pic&t=7930
has some good ideas on a reasonably strong way to mount a winch cradle
Users browsing this forum: No registered users and 236 guests
