It is currently Sat Oct 31, 2026 10:08 pm
Post Posted: Fri Nov 19, 2010 8:14 am
hey guys putting my diff centre back in with new locker installed :lol:
Question when putting center back onto the housing is it just sickaflex between it and the housing?
doing it right now
thanks
Vehicle: I drive your mum
Post Posted: Fri Nov 19, 2010 8:16 am
Yeah just use Sikaflex or simillar. There is a gasket you can buy but no-one uses it.
Layto....
Post Posted: Fri Nov 19, 2010 8:19 am
alright thanks mate
Post Posted: Fri Nov 19, 2010 7:45 pm
Layto....
x2 so much better.
255 characters
Post Posted: Fri Nov 19, 2010 11:50 pm
do not use sika for this, you need to use a proper flange sealant, sika is not designed for oils, fuels ect, the amount of backyarders that use it is a joke.
Post Posted: Sat Nov 20, 2010 12:54 am
Most mechanics use grey silicone, unsure at the mo the name, but every mechanic I know uses it, and just calls it grey silicone..
They say, reason is gaskets can and will leak, so its a root if the do a job then have to redo it because they use a gasket and it leaks.
Post Posted: Sat Nov 20, 2010 1:04 am
have used good old 732 silastic many times and never had a problem,bot even a slight weep or wet spot after probably 5 or 6 diffs with it.
I have also used ultra blue and had no dramas with diffs,tappet covers etc
Post Posted: Sat Nov 20, 2010 1:11 am
I "think" its 735
Post Posted: Sat Nov 20, 2010 5:09 am
Use that blue Silicone gasket stuff, can't remember the name for it. Supershit sell it. Its what they use at Arb!
helloo
Vehicle: '94 suzuki maruti
Post Posted: Sat Nov 20, 2010 1:30 pm
i used it for the rear diff and the oil sump. probably didnt use enough of it, yet theres no leaks...
Post Posted: Sat Nov 20, 2010 9:34 pm
sikaflex will work just fine, but there are specific sealers for this, ie three bond grey one of the best around.
as a general rule most sika proucts are adheasives not sealers although they do also seal.
Post Posted: Sun Nov 21, 2010 7:45 am
I use the black sikaflex that they sell at supercheap. Its the one labeled as oil resistant (I think it even has an image of a sump as an example on it :wink: )
Member of C.O.R 4x4
Users browsing this forum: Google [Bot] and 108 guests
