It is currently Mon Nov 02, 2026 6:03 am
Post Posted: Sun Feb 25, 2007 2:36 am
Being completely ignorant of headlights and what is best, I thought I'd ask if there is a better type of headlight to put on my Zook. It has those 7", 3 pin sealed beam units, which are a bit dull to even read by.
Can Halogen or some other flash type be installed instead? Would doing so impact on the existing wiring/circuitry?
Michael
Vehicle: 75 Cruiser
Post Posted: Sun Feb 25, 2007 12:30 pm
royce is the resident headlight expert, and he has a solution for you :D
Post Posted: Sun Feb 25, 2007 12:53 pm
He sure does. Caspers lights rock :-)
Post Posted: Sun Feb 25, 2007 1:39 pm
somebody say headlights :)
youll need something like these
http://cgi.ebay.com.au/PAIR-OF-NEW-ALTE ... dZViewItem
and a pair of these
http://www.lighting.philips.com/automot ... nplus.html
then make up one of these
Post Posted: Sun Feb 25, 2007 1:43 pm
the biggest problem with sierra lights is the power travels a total of 12 metres through thin wire so the voltage drop is massive
the relays fix that and change it to a direct path from battery to headlight so there is no drop at all
the different headlights use a different focussing method, the beam is focussed via the reflector not the lense so less light is bounced back into teh light and being wasted
then the globes, ive tried all te plus 50 style globes and these were by far the best, plus being proper Quartz they done shatter of they get wet, plus they use the same power as stock, all the 90 / 130W are useless, the extra brightness isnt worth the current loss
Post Posted: Sun Feb 25, 2007 2:57 pm
Yep that's the same lights as Casper as got. He gets flashed sometimes while driving as they think he has hi beam on. :-) then he flashes his hibeam on. :-) This setup is great.
Post Posted: Mon Feb 26, 2007 3:04 am
Thanks guys....I have a bit to think about there....
Post Posted: Sun Oct 11, 2009 9:19 pm
and a pair of these
Hi Royce,
Would you please update this post as the links don't work, and I would like to update my lights before I drive back to darwin.
Cheers, Davo.
Post Posted: Sun Oct 11, 2009 9:47 pm
If people are flashing at you don't you think you're lights might be TOO BRIGHT or need adjustment? :roll:
Post Posted: Sun Oct 11, 2009 9:55 pm
my coily has the halogen lamps anyways so all i would need to do is the wireing hey ? would not need to buy the new actual lights
Post Posted: Sun Oct 11, 2009 10:01 pm
[quote="Saam"]my coily has the halogen lamps anyways so all i would need to do is the wireing hey ? would not need to buy the new actual lights[/quote]
The std`s with this wiring would be hugely brighter, most of the std`s lack is power supply....
Post Posted: Sun Oct 11, 2009 10:06 pm
yeah only thing wrong with my lights is the reflector is a bit aged..
Post Posted: Sun Oct 11, 2009 10:08 pm
hid
its all good then
not legal
but you can see where you are going
Post Posted: Sun Oct 11, 2009 10:10 pm
chuck it all out Sam, especially if the reflectors are dull
everything does its part, the loom gets you all the voltage you can to the globes, the globes make the most light they can with the available power and the reflectors point it where you want it to go, though these days HID kits are cheap as chips and smash this sort of stuff (not legal though)
hehe says the guy who has stock wiring in his vit with a servo globe in one side and an old spare that was under the seat in the other side :)
Post Posted: Sun Oct 11, 2009 10:13 pm
well i have general electric globes in mine which are the best i have come across, doing the wiring for me would be free(including bits), so i'll just do that and if i ever got new lights then it will already be set up for it :)
Post Posted: Tue Oct 26, 2010 11:09 am
Hey Royce the links don't work anymore.. Can you edit? :)
My build: Click WWW
Post Posted: Wed Oct 27, 2010 6:16 am
:P Did you look at the date it was posted?? :lol:
Post Posted: Tue Nov 30, 2010 3:09 am
and a pair of these
i know this was posted a while back is there somewhere i can look at what they are?
thanks scott
Post Posted: Tue Nov 30, 2010 3:43 am
and a pair of these
thanks scott
if Royce could check i think these are the same
http://cgi.ebay.com.au/PAIR-NEW-ALTEZZA ... _500wt_922
lost in suzuki space
Vehicle: '96 LWB trayback
Post Posted: Tue Nov 30, 2010 5:02 am
They're the same as the ones I used, same seller too.
Users browsing this forum: Google [Bot] and 86 guests
