If your torque the nut up as such chances are you will change the preload on the pinion bearings and change the position of the pinion compared to the crownwheel.
Just tighten the nut enough to remove any end float in the pinion (so the crush tube dosn't 'crush' any more than it already has) and lock the nut in place.
Users browsing this forum: No registered users and 375 guests
