It is currently Mon Oct 19, 2026 10:13 am
Post Posted: Sun Jun 01, 2008 10:39 pm
Having problems with hubs not locking in is it a simple fix or better to just replace.
Zook ute, 4.6's, 1.6EFI, Auto, S3 R/H, SPOA, 34"JT
Post Posted: Sun Jun 01, 2008 11:01 pm
pull em off, clean it all up and regrease, put em back in, easy as
Post Posted: Wed Jun 04, 2008 3:50 am
Front dial comes of with 10mm socket
Take the circlip of around the axle on the inside, undo the outer hub bolts 12mm and pull it out clean it all up with degreaser. Pull the dial apart and clean around the seals and clean your spring up and put it all back together see how that goes really easy job.
Post Posted: Wed Jun 04, 2008 1:59 pm
if you leave the circlip off you can pull the whole hub off to swap a cv when you break them. just make sure you bend the tabs back on the lock spacer. makes it a lot quicker and dont need to worry as much about the hub.
just a thing if found out over time.
Users browsing this forum: DamoRed83 and 237 guests
