It is currently Tue Nov 03, 2026 12:44 am
Post Posted: Wed Dec 22, 2010 6:37 am
well i get to keep my jimny now that i got my mony back for the jeep and i was so looking forward to going out over xmas but now theres some play in the frunt left hub and when i tern it makes a rubbing sound and if i tern going back its sort of a clunk do you think its a cv or bearing
Post Posted: Wed Dec 22, 2010 6:54 am
Swivel or wheel bearing, highly doubt the cv will make noise like that
Post Posted: Wed Dec 22, 2010 7:01 am
hey stekky ... to do a wheel bearing on one do you need a special tool? my drivers side has some play in it.
Post Posted: Wed Dec 22, 2010 7:08 am
Yer, me... :roll:
It's a cassete, so c'lip & hammer/pres out & in, no adjustment..
Post Posted: Wed Dec 22, 2010 8:30 am
so if i pull the hub off ill be able to see if its the bearings
Post Posted: Wed Dec 22, 2010 9:16 am
jack it up, put it on stand's & get someone to wobble the wheel, climb under & see if the disc is wobbling with the wheel or if the hole swivel hub is..
If you take the locking hub off you will be able to see the stub axle staying still & the hub moving, but that are a cassette bearing & can't be adjusted..
Post Posted: Wed Dec 22, 2010 6:44 pm
what does the wheel bearing tool undo??
just searching egay and came across it.
Post Posted: Wed Dec 22, 2010 8:34 pm
i got one of the bearing tools, they just help remove the bearing cartridge, as it only has the holes for the tool and not a large hex nut like other forbys have
03 Jimny, 60mm Lift, 215 A/T BFG's, Dual Batts
Post Posted: Wed Dec 22, 2010 10:17 pm
ok so it looks like the disk is wobbling with the wheel but now there's only a little bit of a rubbing sound coming from it not like last night it seemed a lot louder
Post Posted: Wed Dec 22, 2010 11:08 pm
just riped the hub off and there is a lot of play in the stub axle so what bearing do i need wheel? (think its ment to have a bit of play in it so ill pull some more off)
Post Posted: Wed Jan 05, 2011 7:28 am
well still havent fixed my car need to get one of these
http://cgi.ebay.com.au/Suzuki-Jimny-whe ... 19c22f39ea
anyone got one ?? or are there any in aust ??
thanks
Post Posted: Fri Jan 07, 2011 3:47 am
thanks
http://auszookers.com/index.php?name=Fo ... ic&t=15009
:wink:
Users browsing this forum: No registered users and 100 guests
