It is currently Tue Nov 03, 2026 9:04 am
Post Posted: Wed Sep 22, 2010 5:12 am
Hi, tried searching but couldn't find what I was after.
My 96 vitaras reverse lights have stopped working. I have checked the globes and fuses and they are fine. What else could be causing this I'm thinking it's the reverse light switch but I am unable to find this on the 4sp auto.
- jono
Post Posted: Tue Jan 11, 2011 5:33 am
How did you go with this jono?
I reckon my reverse switch has just shat itself. Fuses, globes are fine. There seems to be no power getting to the globes when i tested it with the test light.
anything i could be missing? Where abouts on the vitara 5speed are the switches and are they easy to replace?
Post Posted: Tue Jan 11, 2011 5:55 am
My lights work on and off so haven't really bothered to fix it properly. Mine is an auto and I need to take off the prn switch and clean out the contacts and put it back together. I have seen similar things with xj jeeps (google jeep NSS rebuild for more info)
Yours is a manual so the reverse light switch should be at the back of the engine bay on top of the bell housing area. A new switch can be had for around $20 or so.
Post Posted: Tue Jan 11, 2011 7:04 am
Hey mate, Just pull the originial switch out, and spray Heaps of WD-40 Down around the little ball. should sought it out... worth a try for the 5 seconds it takes to pull out
Stocker
Users browsing this forum: Google [Bot] and 80 guests
