It is currently Tue Nov 03, 2026 12:11 pm
Vehicle: LWB Sierra & XL7
Post Posted: Sun Jan 30, 2011 11:04 pm
A couple of weeks ago I replaced the timing belt water pump, cam and crank seals.
I thought it would've been the crank seal that was leaking but now It's leaking more oil than before.
I've taken it to a mechanic and he tells me it's the oil pump, He said he removed a bolt that hold on the power steering bracket and the leak stops but when the the bolt is in it leaks, I find it hard to believe so I'm taking it to another mechanic for a second opinion.
What do you guy's think it could be...
Post Posted: Sun Jan 30, 2011 11:20 pm
OOOO I know this one :)
the bolt that makes it leak is too long, stick one 5mm shorter in :)
Post Posted: Sun Jan 30, 2011 11:24 pm
Alright I'll give it a crack.
'92 Vitara & Camper trailer
Post Posted: Tue Feb 01, 2011 12:04 am
very weird, this is the bolt in question, I've let the engine run for a bit and no leaks. I wonder what is causing it, there is no oil on this bolt.
Post Posted: Tue Feb 01, 2011 12:06 am
I dont know why or what makes it do it or what its pushing on, just had the same problem with Bruces when we put power steer in it :)
Post Posted: Tue Feb 01, 2011 12:39 am
Well I got another bolt and chopped it down, just to be sure I put some gasket goo on it. :)
fingers crossed.
Post Posted: Tue Feb 01, 2011 3:07 am
:woohoo:
Thanks big time Royce, it worked !!!
Users browsing this forum: No registered users and 105 guests
