It is currently Wed Nov 04, 2026 2:20 am
Post Posted: Mon Feb 14, 2011 8:11 am
Ok,
Now that efs has a online store im going to finally upgrade my rear springs.
Question is do i get
Rear Leaf Springs SUZ-05E 2 Constant 80 kg to GVM ----50mm lift
OR:
Rear Leaf Springs SUZ-05E 2 Comfort - Up to Constant 60 kg. ------65mm lift
So are the 65mm lift springs softer? Does anyone know which spring is longer?
Im after the longest/softest spring they have. Ive sent a email to them but im impatient and maybe somebody already knows the answer
Post Posted: Mon Feb 14, 2011 8:20 am
pritty sure its the 65 mil .thats the ones im running
Post Posted: Mon Feb 14, 2011 9:16 am
has anyone run the efs springs on a lwb if so do they sag much on the driver side ?
My Maruti build, Click WWW
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Feb 14, 2011 10:12 am
Is it worth the few extra dollars to go EFS over OME?
Post Posted: Mon Feb 14, 2011 1:03 pm
Hell yes!
Its like saying is it worth the extra few dollars to buy a house over a jumping castle! :P
The comfort springs will most likely have the little plastic slip pads in them, the others will not. All my EFS rears have had the slip pads in them.
Clearance Hole Technology :P
Post Posted: Mon Feb 14, 2011 9:47 pm
Let me know which you end up choosing birko
Post Posted: Tue Feb 15, 2011 6:14 am
ok, No email back yet. I want the softest ones but dont really want 65mm lift. How can more arched springs be more comfort :?
Post Posted: Tue Feb 15, 2011 6:15 am
softer maybe ? i don't know....
Post Posted: Tue Feb 15, 2011 6:30 am
To have the lift you generally need the higher spring rate, thus a reduction in comfort. With all the EFS springs Ive had a play with needed quite a few leafs removed. Straight from the factory the lift was huge but you may as well have had no shocks at all, they were stiff they barely moved at all!
Lil Foot!
Post Posted: Tue Feb 15, 2011 6:33 am
So you have had both the 50 and 65mm lifted ones? I have seen your build thread which were they?
Users browsing this forum: Google [Bot] and 76 guests
