| Author |
Message |
Vash
Joined: Fri Feb 04, 2011 3:12 am Posts: 130 Location: Sydney
 Posted: Wed Feb 23, 2011 9:22 pm |
If you fellas saw my other thread i had a severe wobble and clanking when going over speed bumps.
I only just got my sierra on monday, then took it to pedders.
and check out this quote guys...
wait for it.
$3023.08
Springs are sagging 4 inches (probably an exaggeration by them)
Front shocks are stuffed
Steering damper stuffed
Swivel hub & bearings
Gearbox mount was f**ked, he was moving the gearbox around with his hand.
Same with motor mounts.
So i definitely won't be going ahead with that quote but its nice pedders run you through all the problems and physically show you under the car. Now i can source cheaper parts and do it myself (except perhaps the swivels as he says they're a bitch to do)
And he's got cheap 2 inch raised springs he can sell cheap since a previous customer ran off after ordering em' so i might go ahead and go for those.
Anyway what do you fellas reckon i should source myself and fit myself, and get pedders to do?
thanks.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Feb 23, 2011 9:26 pm |
I wouldn't let Pedders touch my wheelbarrow.....
5ierra
Joined: Tue Mar 09, 2010 10:30 pm Posts: 1645 Location: Ipswich
 Posted: Wed Feb 23, 2011 9:30 pm |
Swivels arent too bad, just time comsuming. If you have a mate that can help and you know what you are doing you will be fine...
all of that (less buying new springs) should cost around $500 at most...
tanshi
all of those things including swivel seals you can do your self reasonalbly easy
BlueSuzy
 Posted: Wed Feb 23, 2011 9:34 pm |
If you slightly mechanical minded, and you know how to search this site for info, Do it all yourself.
4" sagging springs? Stock springs only have 2" sag before they get to the bumps..
Shocks are the simplest things to replace-$200ish guessing for parts
Dampner same-$100 part only
Swivel hubs and bearings, 'Weaves' may be able to help you out with a kit, or get one from lowrange.com, or other parts places will supply them. $? They are not a bitch to do..Bit unprofessional.. They are just time consuming. pull out, clean, regrease etc.
Gearbox mount is simple also. 6x M8 bolts..
Motor mounts simple also..
Do not get the 2" springs off him, probably cost you 2k with the rest of that price....
OR
Give it to me, i will do it for 2k with parts included..
Vash
 Posted: Wed Feb 23, 2011 10:14 pm |
he's got the 2" springs for cost price $280
but the rears are $400 to match.
Heres the quote as i didn't list everything
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Wed Feb 23, 2011 10:18 pm |
Pedders are great! There's a reason their logo is a bull wearing a helmet ... and that's that they charge like a wounded bull! lol
I've used them occasionally for their 28 point safety check. Quite happy to pay $14 for them to put it up on the hoist and look over it, then take the report and fix whatever they've identified myself.
S13RR4
Joined: Sat Aug 22, 2009 11:30 pm Posts: 1072 Location: Sunshine Coast
 Posted: Wed Feb 23, 2011 10:32 pm |
my rear 2'' springs cost $111 each from Arb,
my front 2'' springs cost $81 each from Arb,
Full rubber bushes off ebay for around $60. easy to do when swapping springs
remove the sway bar.
Me and me brother rebuilt my front swivel hubs in a day, both sides (me no experience with swivel hubs, brother with experience from rebuilding his hilux)
shocks can be done in 10 minutes, the gabriel part numbers are available on this site and can be bought for $45 each at super cheap.
springs are easily done, last time I did my fronts it took me 1hr to do both sides. (had done it about three times in the preceeding month) first time took me a couple of hours
engine mounts can be bought off ebay for around $45-50. Straight forward to swap out if you have something to support the engine.
Same for gear box
You'll be able to do it for a but load cheaper, and you'll learn how your car is put together and be able to better maintain and repair it.
also theres an $87 on the last page that is for nothing...
JMHO
_________________ My Rig --> Click WWW
JrZook
 Posted: Wed Feb 23, 2011 10:34 pm |
In regards to your wobble problem :tires uneven wear???
_________________ Lil Foot!
BlueSuzy
 Posted: Wed Feb 23, 2011 10:42 pm |
JMHO
What about the 1st page..  $40
The parts are not dear. The labour is!
Give me $127 and i will do nothing too.
Vash
 Posted: Wed Feb 23, 2011 11:11 pm |
5ierra
 Posted: Wed Feb 23, 2011 11:18 pm |
Vash wrote: how about this for a leaf spring, shock & ubolt kit? http://cgi.ebay.com.au/Suzuki-Sierra-2- ... 288wt_1139cheers
Why bother? Are your U bolts or bushes rooted?
You can put together a kit better then that yourself for the same price, if not cheaper...
Theres more then enough information on this site to get you sorted...
If i were you, i would be looking at taking this as an oppourtunity to do abit or work.
-Sort out a rear up front
-Commo/hilux shocks
-Replace mounts/upgrade mounts
-rebuild swivel hubs
-buy my monroe damper for $60  (brand new, never used  )
You could easily fix all of these issues in a weekend hey. I'm sure there would be plenty of blokes down in sydney that could give you a hand for an hour or two aswell
Vash
 Posted: Thu Feb 24, 2011 12:49 am |
they're all rooted mate
Whats the plus on commo/hilux shocks? what years fit ?? argh too many questions!
I'll most definitely go for your damper since mine is the original with 235kkm on it
Cozook
Joined: Thu Sep 11, 2008 11:30 pm Posts: 725 Location: Blue mountains.
Vehicle: 98 coily..Max.
 Posted: Thu Feb 24, 2011 2:10 am |
Vash buddy............prepare yourself to be bitten by the bug..
Welcome to the club............go for it!
_________________ Suzuki...four wheel jive!
98 coily...Camping rig.
Vash
 Posted: Thu Feb 24, 2011 3:21 am |
lumpy_zook
Joined: Thu Jan 27, 2011 2:15 am Posts: 108 Location: whyalla
 Posted: Thu Feb 24, 2011 3:45 am |
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Thu Feb 24, 2011 5:19 am |
want33s wrote: I wouldn't let Pedders touch my wheelbarrow.....
I want to write something about pedders and pedophiles but i think it would be in bad taste!
_________________ Chop
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Thu Feb 24, 2011 6:00 am |
Whilst my car would never go anywhere near pedders, lets be honest, all the parts prices listed here are retail for like-for-like replacement, and $1K worth of labour, whilst it seems high, would be about right ( I guess it would be a very full day or maybe a day and a bit.)
Is it a lot money? Hell yes - I've just bought a tow rig for less, but a workshop has to make a living, and a franchise will have parts prices and labour rates set for it, and none of those prices are exorbitant from what I can see.
Would I pay it? No, but I do all my own work and have all my own tools, so I'm not a pedders customer.
By all means take you money elsewhere, but is the quote "insane" - based on parts and labour, no, actually it isn't.
losfer
 Posted: Thu Feb 24, 2011 7:03 am |
the labour certainly seems on the rich side
