It is currently Thu Nov 05, 2026 3:21 am
Vehicle: 4wd
Post Posted: Sun Mar 20, 2011 8:31 am
Another easy mod. Very light bar so second person not required.
Cost: $0
Tools required: 16mm, 17mm spanners
Time required: 5 minutes
Loosen all four bolts attaching the bar to the bracket a turn or two. Remove the most forward of the two bolt on either side.
Lower the brush bar down so it's resting on the ground.
Remove the other two bolts, and the bar is ready to pull off.
All thats left to remove is the brackets. This would be alot easier if the bumper bar is removed first, but not necessary.
Watch out or you'll get sued.
Users browsing this forum: No registered users and 467 guests
