It is currently Sat Nov 07, 2026 10:58 am
Post Posted: Mon Feb 21, 2011 10:22 am
will coily door trims/cards clip straight into my leafy doors cheers
Post Posted: Mon Feb 21, 2011 10:24 am
Yes they will clip on but you will need to make a little bracket for the handle bit
Ill go find a link so you know what im talking about :wink:
yes they will. Little mod needed but easy.
My Maruti build, Click WWW
Post Posted: Mon Feb 21, 2011 10:25 am
thanks guys
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Mon Feb 21, 2011 10:32 am
I went to the trouble of making a little bracket on each door to fix the coily door trim too, just something to give it a bit more support when pulling the door closed, could have just used a bit of angle, but this is all I had lying around.
Post Posted: Mon Feb 21, 2011 11:02 am
I didnt bother with the extra holder, i shut my sierra doors with the window frame anyway.
When locked, the original button is hard to get under to pull up to unlock, you get used to it..Everything clips in, looks good. with the pockets, i got some foam stuck around just under the lips and popped them in. No rattles.
I plan to do these again for my lwb! Just makes everything look neater, bit newer.
Vehicle: Sierra Ute '87 Sj70
Post Posted: Wed Feb 23, 2011 1:49 am
will coily door just bolt straight on and will all the body lines match and everything?
It's all coming together Armsup
Post Posted: Wed Feb 23, 2011 2:17 am
Hey bluesuzy, what seats are those and what did they set you back?
cheers
Post Posted: Wed Feb 23, 2011 7:13 am
saas $300 special. Dont get them! Get the autotechnica 300 ones. Easy to bolt into a later leafy. Same shape as saas. Search seats. Few threads on them.
Post Posted: Sun Mar 13, 2011 9:42 am
anyone know about this?
Vehicle: Vitara
Post Posted: Mon Mar 14, 2011 7:02 am
Can I ask where you got your door cards from?
Repping it, High Top style!
Post Posted: Mon Mar 14, 2011 10:15 am
yer x2 i want them
Post Posted: Mon Mar 14, 2011 11:06 am
96+ coily sierra
Full plastic door panels.
From....My sources :P
Vehicle: Vitara
Post Posted: Mon Mar 21, 2011 7:44 am
Lol dam your sources.. They are rare as hens fangs.. Looks tops tho :)
Users browsing this forum: No registered users and 90 guests
