It is currently Mon Oct 19, 2026 1:55 am
Post Posted: Mon Jul 28, 2008 3:05 pm
I think my engine running rough could be dirty injectors. They had fuel left in them for about 2 years so they could be gummed up. Where's a good place in Brissy to take them to get cleaned?
Damo.
Post Posted: Mon Jul 28, 2008 3:11 pm
I always use some mobile mob I cant remember that name of but anyone that can ultrasonic clean and flow test should be OK
be sure they do before and after spray and flow test, no use cleaning them if they dont know how bad they were and how good they are now
BTW does it run rough at all revs or jsut idle? could be airleaks as well
Post Posted: Mon Jul 28, 2008 7:11 pm
It just seems to run like shit generally. The most likely lace it could be leaking is in between the two halves of the manifold runners. I will unbolt that section to get at the injectors and i'll put some gasket goo in there.
Post Posted: Mon Jul 28, 2008 7:15 pm
all you vacuum hoses on tight? all in the correct spot?
mine used to run like crap and chewed fuel till I went through and put clamps on all the bigger vacuum hoses and zipties on the little ones, difference in power was amazing and dropped consumtion 3l 100km too
Post Posted: Mon Jul 28, 2008 7:19 pm
I'll put that on my list of things to check, thanks Royce.
Post Posted: Tue Jul 29, 2008 11:35 am
Mobile Injector Service. We use them for all our injectors, they're good.
Post Posted: Tue Jul 29, 2008 12:53 pm
You got a number for them? I can't find em.
I pulled the injectors out last night but forgot to bring them into work :(
Post Posted: Tue Jul 29, 2008 1:08 pm
Got mine done in my Z with this guy....
Company: Electronic Injector services
Mobile: 0418 884 678
He was really good - comes out to you wherever....
Post Posted: Tue Jul 29, 2008 2:34 pm
His name is Vaughan (good name!)
0412 490 961
Users browsing this forum: No registered users and 408 guests
