so my brake lights have stopped working, globes are fine but i put a test light in and have no power to the plug sitting above the pedal and no fuses are blown.
Joined: Tue Aug 03, 2010 7:56 am Posts: 198 Location: brisbane
Posted: Wed Mar 30, 2011 12:22 pm
it should be in the fuse box, check the legend on the back or inside of the fuse box for brake lights. Have you tried a different fuse ? start at the power source (fuse box) then work it from there. if theres power at the fuse then its a broken cable.
it should go from fuse box to the switch then to lights.
Users browsing this forum: No registered users and 75 guests
