It is currently Thu Nov 05, 2026 6:45 pm
Post Posted: Sun Apr 17, 2011 12:40 am
Ok so I'm putting my wt diffs under a nt
I had a read through bogfrog thread but being me I don't understand any of it :oops:
I don't know why I don't get it :?
Is there a better write up of what I'm after or is bogfrog thread the easiest write up there is?
Links would be good
Post Posted: Sun Apr 17, 2011 12:51 am
Um what dont you get?
Lil Foot!
Post Posted: Sun Apr 17, 2011 12:56 am
Were to weld the new perches on the diff( how far in)
Maby I'll read it over nd over again till I get what he's saying
Post Posted: Sun Apr 17, 2011 12:59 am
measure the distance between the center holes in the springs... now subtract that from the width of the diff housing end to end, divide that number by 2, then measure that far in on each side of the diff housing and you have the center point of your perch.
make sure you get the pinion angle right.
Post Posted: Sun Apr 17, 2011 1:02 am
The w/t perch's need to be moved in 40mm, it is vital that they stay on the same plane, that's your caster adjustment......
the n/t r/h side perch is also a different shape to the l/h, being that it has to sit on the pumpkin a lil bit, so, i in the past have sacrificed the n/t housing's to save the perch buy cutting the tubing beside the perch, then take your time picking the pesrch of..
Or, buy a set of TSOR's perch's, have used em a couple of time's & love em, new steel is so mush nicer to work with.....& you don't have to be as careful with the ole one's.....
it is 45mm a side. from memory so best ya check yourself.
edit: steeky beat me. don't trust my measurements :lol:
Post Posted: Sun Apr 17, 2011 1:04 am
Oh, I'm looking for some pic's I have some place in this computer...
:roll: may have to put my steelcap's on & re-boot it.....
Post Posted: Sun Apr 17, 2011 1:12 am
Call in here and I'll show you the jig I made up for moving the perches... It is very basic but works well.
Post Posted: Sun Apr 17, 2011 1:55 am
Are you home today jas
Might go for a drive
Post Posted: Sun Apr 17, 2011 2:13 am
So I think I worked it out
wt diff spacing is 950 and nt diff spacing is 870
So 950 - 870 = 80 \ 2 is 40mm
So perches have to be welded on wt diff 40mm in from center hole of the wt perch
Is this all correct
Also I already have the perches from fatzook
Post Posted: Sun Apr 17, 2011 4:33 am
Is this all correct
Rear are wider than the front............
Post Posted: Sun Apr 17, 2011 4:53 am
Rightio That was the rear I did Just then
Users browsing this forum: UBZ and 33 guests
