It is currently Mon Oct 19, 2026 3:17 am
Post Posted: Fri Aug 22, 2008 11:12 pm
Just wanna now what diff and stuff you use to replace the alloy diff stuff on the vit that arrives at mine soon.......
CHEERS
back in a built sierra!
Post Posted: Fri Aug 22, 2008 11:23 pm
More info please. Year of Vit. rear diff ratio etc.
Post Posted: Fri Aug 22, 2008 11:52 pm
providing the alloy diff is ok you need a steel housing and carrier out of a GV, 2000 onwards manual have them and 2003 onwards have them
then get your gears and hemisphere fitted to the steel carrier and slot it all into the front
Post Posted: Sat Aug 23, 2008 3:46 am
92 manual vit got the front alloy diff that is apparently weak as do you replace the diff and housing or just the housing?
Post Posted: Sat Aug 23, 2008 12:19 pm
the only thing you keep is the crownwheel, pinion and hemisphere (if you arent fitting an airlocker)
Post Posted: Mon Aug 25, 2008 3:47 pm
Will be goin an air locker soonish.....
So when that go's in all i need is the diff housing yeah?
Post Posted: Mon Aug 25, 2008 3:54 pm
you need the housing (big bit that the axles and centre bolt into) and the carrier (round bit the pinion and locker bolt into)
Users browsing this forum: No registered users and 205 guests
