It is currently Thu Nov 12, 2026 11:09 pm
Post Posted: Thu May 05, 2011 10:46 am
Just wondering if anyone on here has removed the vacuum choke set up off of their Sierra before? After 13 faithful years the old coily carb is starting to give me the shits! any info would be appreciated.
Cheers Richo
97 Coily 2" susp lift 2" body lift + more
Vehicle: 94 Sierra
Post Posted: Thu May 05, 2011 10:50 am
you can zip tie the choke fully open...
Thats what i did when it started to shit me
Post Posted: Thu May 05, 2011 10:56 am
there is no vacuum choke, its coolant powered
after 13 years try servicing and repairing whatever is wrong with the carb rather than just chopping bits off it
Post Posted: Thu May 05, 2011 11:40 am
What is the carb doing for you to get the shits?
Post Posted: Thu May 05, 2011 12:11 pm
As far as i know it is a choke issue, at the rear of the carby (closest to firewall) there is a plastic cog with a metal lever type thing attached to it and lately the engine has started idolling at around 2500rpm and when i push down on that lever the revs drop down to around 800 however when i let go the revs go back up, i tried adjusting this via the lock screw underneath which seemed to fixed the problem for a while but it has started idolling at around 2000rpm now.
Richo
Post Posted: Thu May 05, 2011 6:55 pm
Sounds like you're closing the butterfly.
Push harder on it and see if it stalls.
Get it tuned, solved my idle speed and mixture issues.
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Thu May 05, 2011 11:45 pm
Check that there is water flowing through the choke assembly. One of the pipes attaches to the manifold with a "T" section which has a flow restrictor in it. This can get blocked up easy.
Post Posted: Thu May 05, 2011 11:52 pm
Fity wrote:
Check that there is water flowing through the choke assembly. One of the pipes attach to the manifold with a "T" section which has a flow restrictor in it. This can get blocked up easy.
x2
also check you actually have a full cooling system
Post Posted: Fri May 06, 2011 4:40 am
will do,i just fitted a new rad as the old one was blocked as so chances are it may be blocked also. Thanks for the input.
Richo
Users browsing this forum: No registered users and 61 guests
