It is currently Fri Nov 13, 2026 6:03 am
Post Posted: Fri May 06, 2011 1:10 am
I have a WT diff I have used in 2 of my NT sierras over the past few years.
Its been given a bit of a hiding and i bought it from another bloke who had given it a bit of a hard time also.
Im in the process of building my new LWB and Im thinking I should really confirm its straight and ready to go. Otherwise Im going to put the Cromo's locker and diff gears in it and drive it down the road and find its CRAP!
So the magic question is, how can you tell its straight?
Or is it a case of the old "high tech" machinery.
Post Posted: Fri May 06, 2011 1:43 am
use eye for starters u should be able to look straight through, this is how rooted mine was
Post Posted: Fri May 06, 2011 7:23 am
So far from what I can tell its OK via the eye.
Post Posted: Fri May 06, 2011 7:28 am
I use a laser level with dot function. Shoot through the centre of one side onto a piece of paper on the otherside. Its ok to be out by a little bit.
Post Posted: Fri May 06, 2011 7:50 am
farrrk!
Post Posted: Fri May 06, 2011 7:55 am
Good thinking!
I might get a piece of string and put it through and make it tight then have a look at some clearance from there, making sure the diff will be airbounre on stands or timber, etc.
Post Posted: Fri May 06, 2011 8:09 am
Good thinking!
That will work too.
Get a mate to help. You can tie a can at each end of the string to help with communication :wink:
Post Posted: Fri May 06, 2011 8:16 am
Good thinking!
That will work too.
:rofl: :rofl: :rofl: :cheers:
Champagne comedy!~
Post Posted: Fri May 06, 2011 8:18 am
Good thinking!
That will work too.
so this is why the ute is taking so long you using stone age technology
Users browsing this forum: No registered users and 111 guests
