It is currently Fri Nov 13, 2026 3:02 am
Post Posted: Fri May 06, 2011 11:55 pm
Hey just wondering if any ones knows were you could buy or get brand new wt axles for a Sierra
Or is it better To spend te money why te dollars are good nd get cromolys front axles and HD rear axles
The wt axles I have now have a bit of play were the spline goes into the center and I want to replace them
Post Posted: Sat May 07, 2011 12:00 am
Meh - spline wear is the last thing I'd worry about. Drive them until they break IMHO.
Then step up to cromo front. There's no point spending more money on less axle. DT's are so cheap it's a no brainer.
Leave the rear alone. By all accounts the cromo rears aren't much of an improvement over stock. If you really want to upgrade the rear end (and I'd only do it if you have a problem with axle breakage) look at Joe's floater kit, which is a much better upgrade than just some HD axles.
Post Posted: Sat May 07, 2011 12:13 am
I don't really care about breakage it's just I'm doing a full rebuild and I don't want some thing that's weared already that will wear down a new part if you no what I mean
I'll be getting airlockers soon so the stock axles should hold up right?
I'm only running 30's with 4.16 gears
Post Posted: Sat May 07, 2011 1:14 am
It should be very hard to break a stock front axle with 30's and 4.1 gears, however if you are buying airlockers, then why not buy two rears and upgrade the front to DT's while you are at it.
It's more expensive to upgrade a front airlocker to 26 spline to accept a DT axle later on than it is to buy DT's now.
I'd argue it's pretty hard to isolate the wear to the axle spline. I'm guessing the stub axle spline to free wheeling hub, the CV, the side gears, and the cross shafts are all a bit worn. It's not really a concern, especially in the front where it's only used intermittently.
I've pulled apart 25 year old diffs, welded them, put them back together, flogged them on 34's for 18 months - when pulled apart, they still didn't really have much spline wear.
As I said, I would have worried about it, but as you have mentioned buying lockers, it would be silly not to upgrade now- there doesn't have to be another reason except buying the locker.
Post Posted: Sat May 07, 2011 1:16 am
you can break them on standard tyres with a locker just depends on driving style, find a 2ndhand pair in good nick is the best bet, some people never have a prob while others snap them everytime they go out.
Post Posted: Sat May 07, 2011 1:48 am
I was just worried about the the axles wearing out the side gears in my new locker that's all
Is there any other advantage putting a rear in the front so you can run 26 axles
Is that the only advantage putting a rear locker in the front
Im gonna get cromoly For the front and just stock a couple of rear axles so when I break one I can replace it
Excuse my knowledge but what are dt axles
Post Posted: Sat May 07, 2011 2:29 am
DT=Double Tough = Trail Tough's cromo front axles.
All cromo front axles are 26 spline, so yes, the only advantage of upgrading to a rear locker for the front is to run 26 spline axles.
All cromo front axles also run exactly the same CV and stub axle. the difference between a, say, Spidertrax cromo axle and a Trail tough double tough is the maker of the inner axle.
However, spending $1K on a front airlocker and then wiping out a 22 spline inner axle would be annoying, no?
I'll add that generally, the 22 spline inners don't go until you've added birfield rings to the stock CV's.. because you're sick of breaking stock CV's.
Post Posted: Sat May 07, 2011 5:14 am
Ok thanks Steve
I'll be running a front locker first untill I save up for a rear one
So I'll get a RD88 locker for the front and run the DT axles and run the standard rear axels and just replace as they break
If they keep breaking I might consider Joeblows axel kit
Post Posted: Sat May 07, 2011 5:19 am
I think that's a great way to go.
I think there's approximately 0.0000000001% chance of you breaking a stock rear axle with 30's. If you do though, there's lots of other good reasons to go to a floater, like rebuildable rear wheelbearings and discs.
Should be a nice reliable setup.
Post Posted: Sat May 07, 2011 5:30 am
Already doing the rear disc conversion
Should be in the mail :)
Post Posted: Sat May 07, 2011 8:17 am
I run 32.8" tyres on stock rear axles and never had a drama...
Don't stress Aaron.. You've got to do some pretty crazy/stupid driving to break a rear axle.
Post Posted: Sat May 07, 2011 8:38 am
I have all but ruined the splines on my rear axles from a g16b and 29s.
So I'm just not taking the chance now the j20 is going in.
Imo if you can afford to upgrade you should.
Post Posted: Sat May 07, 2011 9:21 am
Yea okay I'm just worried about the axels wearing out my side gears
Idc about snapping them
I have the money to upgrade
So im gonna just upgrade the front so I can put the rd88 locker in
Users browsing this forum: No registered users and 31 guests
