It is currently Mon Oct 19, 2026 5:14 am
Post Posted: Mon Sep 01, 2008 4:11 pm
This is prolly only marginally tech, but anyway.
I already have some 5" 2 ways in the stock locations. I came across my 6" set and I think I might be able to sneak those into the kickpanel with a bit of butchering.
I don't want to put any in the doors coz the doors get removed, and I might make some half doors one day.
I was thinking the way to do it would be to cut clearance in the kickpanel and mount the speakers to a board that screws onto the kickpanel.
Post Posted: Mon Sep 01, 2008 4:13 pm
I had 8's and 5's in my kickpanels :)
made an MDF board up and routered slots int he back to clear the ribs and put the 8 down the bottom and just chopped a hole in the steel and the 5 over the stock location
Post Posted: Mon Sep 01, 2008 5:51 pm
Yeah that sounds good to me, it would be nice to not have to cut any more holes than absolutely neccessary. How did you have the speakers hooked up? I'd set each pair up in parallel and run them off a 2 channel. It will run at 2 ohms no worries.
Post Posted: Mon Sep 01, 2008 6:17 pm
pfft not cutting holes is overrated :)
4ch amp + active crossover, 8's do up to 500hz and 5's above that
Post Posted: Mon Sep 01, 2008 6:48 pm
I've got an active crossover to run on this thing too if I want, and I should probably do the same BUT it would mean having to run 2 amps (and I do happen to have two 2 channel amps exactly the same), which would mean I then need ANOTHER amp for my sub. Hmmm....
The other alternative is parallel the speakers up like I said before and use passive crossovers.
Post Posted: Mon Sep 01, 2008 6:53 pm
proabbly wouldnt hurt cause they will muddy each other up and do stupid things if they both play fullrange
Post Posted: Mon Sep 01, 2008 6:58 pm
I do have a dodgy little 4 channel that i'll bridge to run my sub in the meantime, but the fronts might end up being too much for it. MB Quarts run by two rockford 45.2s :P the sub is a JL 12W0 but the amp I have to push that is a little on the small side...
Vehicle: 75 Cruiser
Post Posted: Mon Sep 01, 2008 7:08 pm
too much geek talk, not enough wheelin :thefinger:
did I mention I have a nice 1 ohm stable monoblock amp kicking around my garage :wink:
Post Posted: Mon Sep 01, 2008 7:13 pm
I'll give you a yell once I find a nice dual voice coil sub :P
Post Posted: Mon Sep 01, 2008 7:21 pm
it will still do 500wrms into 4 ohms :wink:
Post Posted: Mon Sep 01, 2008 7:58 pm
Prolly a bit much for my little 12W0, they're 125w continuous.
Post Posted: Mon Sep 01, 2008 8:01 pm
it will take it :wink:
Users browsing this forum: No registered users and 230 guests
