Posted: Fri May 27, 2011 2:34 am
It should be fine.
AFAIK you can run an 8v head on a 16v block, but not the other way around, as the 8v pistons don't have enough valve reliefs. ( but you could always buy 16v pistons for the 8v bottom end....)
yeah thats exactly what i have, I'm using 16v pistons, on the notion i may one day go efi.
The G16B timing kit is wider then the A do you have the crank timing belt pulley for the G16A? just use that and do the whole thing up as a G16A with the timing cover and everything for the A.
Any other questions about the setup feel free to ask, though it was all very straight forward
Users browsing this forum: No registered users and 80 guests
