It is currently Mon Oct 19, 2026 6:47 am
Post Posted: Wed Sep 24, 2008 10:07 pm
Ok, heres a couple of stupid questions that ill probably figure out as soon as a reply if made.....
What is a virtual lift??? ive seen a few guys list it as a mod
whats the difference between a 1 litre transfer with and without 4wd switch??? is it just for the dash light??? how many different 1 litre transfers are there? i have an 85 1.3 narrowtrack. will all 1 litre transfers fit or do i need a later model one?
cheers :D
Post Posted: Wed Sep 24, 2008 10:11 pm
virtual lift is lifting up the flares and outer part of the wheel arch to give more room, same clearance as a bodylift more or less
the 1 litre transfer with a switch uses the same spline size as 1.3 transfers so you can bung your flanges on and bolt your tailshafts up, the one without the switch is different so you need to bodge up you shafts to fit 1 litre yokes to fit or otherwise adapt them
the switch with the light also has the fancy gears inside to cut up to make a rocklobster transfer
Post Posted: Wed Sep 24, 2008 10:28 pm
ahh and then there are the t/cases with a switch but early splines.....have 2 here.....
Post Posted: Wed Sep 24, 2008 10:37 pm
quick smash them so my story still holds water!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Vehicle: 75 Cruiser
Post Posted: Thu Sep 25, 2008 10:26 am
Virtual Lift.....
http://www.izook.com/tech/samurai/body/wheelwells/wheelwells.htm
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 224 guests
