| Author |
Message |
suzooky87
 Posted: Sat Jun 11, 2011 2:27 pm |
 Hi guys.
I need some safety advice on some modified (N/T to W/T spacing) axle housings i bought off ebay.
here are some pics on some of damage and seemingly dodgy fab work. The housings them selves are straight but the perches are a little off. caster angles are good though.
DropBear8
Joined: Tue Oct 19, 2010 12:00 pm Posts: 556 Location: Perth
 Posted: Sat Jun 11, 2011 2:31 pm |
 Fruck that. Maybe try to grind them off and get new perches i know fatzook makes a set i think around the 260 mark for four with free posting.
_________________ screwdriver's on ur head impale DropBears
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Sat Jun 11, 2011 2:35 pm |
DropBear8
 Posted: Sat Jun 11, 2011 2:39 pm |
Fatzook
 Posted: Sat Jun 11, 2011 2:43 pm |
DropBear8 wrote: 8O  Well my price was waaayyyyyy out and i was to lazy for a link.
Hahahaaaaa Not even Snake Racing are that dear
suzooky87
 Posted: Sat Jun 11, 2011 2:45 pm |
man u guys are quick!!!
thanks a bunch, will do that. but what do u think about the slightly crushed axle tube?
Fatzook
 Posted: Sat Jun 11, 2011 2:49 pm |
Thats from the U-bolts. I've seen alot of them like that. Should be fine.
The welds look a bit ratty but they should be ok.
suzooky87
 Posted: Sat Jun 11, 2011 2:55 pm |
so u reckon they are fucked, or do u think they are saveable. should i strengthen the tube or leave it? just a bit worried about bending.
Fatzook
 Posted: Sat Jun 11, 2011 3:17 pm |
suzooky87 wrote: so u reckon they are fucked, or do u think they are saveable. should i strengthen the tube or leave it? just a bit worried about bending.
Are you going to do high speed jumps?
If not, then just leave it. Like I said its quite common. Welding braces to your diffs is more likely to cause them to bend than the dents from the U'bolts.
steak_knife
 Posted: Sat Jun 11, 2011 8:42 pm |
Is it just the pic's, or are those perch's bent.....
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sat Jun 11, 2011 9:00 pm |
i know some one that wont be happy you said its dodgy welds
spring pads are stock pads cut off and reused, tsor wasn't selling his when these were done. housing are straight and were welded in a brace. the bent bits your are talking about are from u bolts rubbing
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sat Jun 11, 2011 9:01 pm |
steak_knife wrote: Is it just the pic's, or are those perch's bent.....
Your bent
_________________ Shep is a closet jimny lover!!!!
steak_knife
 Posted: Sat Jun 11, 2011 9:03 pm |
Rusho wrote: steak_knife wrote: Is it just the pic's, or are those perch's bent..... Your bent
You say that like it's a bad thing....
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sat Jun 11, 2011 10:14 pm |
X2 for Fatzook's comments. The workmanship isn't all that great but I can't see anything really terrible happening.
Welding perches properly (taking into account caster, spacing welding etc) isn't all that easy. If the caster and spacing is right with these, leave them alone. They're not going to break - they just look crappy.
suzooky87
 Posted: Sun Jun 12, 2011 3:44 am |
Brett wrote: i know some one that wont be happy you said its dodgy welds spring pads are stock pads cut off and reused, tsor wasn't selling his when these were done. housing are straight and were welded in a brace. the bent bits your are talking about are from u bolts rubbing
So you know the maker of these axles?
Sorry mate but the welds are not a bad effort. But this is an axle housing I feel if they were inspected they would be failed. Apparently it was done by a boiler maker, I have only completed 2nd yeah back in 2007 and I am quite sure I can do better. No offense, just a concern.
suzooky87
 Posted: Sun Jun 12, 2011 3:55 am |
Thank you all for your input. I feel much better about using these housings. Just hope I have not offended anyone. Will let u know if they break once I put them in the Lwb. The plans are to lift (the least I need to make it work) lock ( front air, back lock rite) gear ( 6.5 transfer) big 33" maxxis bighorns tyres with f100 wheels. Will take me a fair while to do it all while I am at uni for the next 3 years, still buying parts, plans will prob change. Any way, thanks alot
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sun Jun 12, 2011 4:12 am |
suzooky87 wrote: Thank you all for your input. I feel much better about using these housings. Just hope I have not offended anyone. Will let u know if they break once I put them in the Lwb. The plans are to lift (the least I need to make it work) lock ( front air, back lock rite) gear ( 6.5 transfer) big 33" maxxis bighorns tyres with f100 wheels. Will take me a fair while to do it all while I am at uni for the next 3 years, still buying parts, plans will prob change. Any way, thanks alot
If you are getting an air locker put it in the back for better on road manners, and power steering for the front.
suzooky87
 Posted: Sun Jun 12, 2011 4:17 am |
Rusho
 Posted: Sun Jun 12, 2011 4:26 am |
Red89 wrote: suzooky87 wrote: Thank you all for your input. I feel much better about using these housings. Just hope I have not offended anyone. Will let u know if they break once I put them in the Lwb. The plans are to lift (the least I need to make it work) lock ( front air, back lock rite) gear ( 6.5 transfer) big 33" maxxis bighorns tyres with f100 wheels. Will take me a fair while to do it all while I am at uni for the next 3 years, still buying parts, plans will prob change. Any way, thanks alot  If you are getting an air locker put it in the back for better on road manners, and power steering for the front.
I was always under the assumption front air was the way to go. Aids in steering ability I thought
Red89
 Posted: Sun Jun 12, 2011 4:32 am |
Rusho wrote: Red89 wrote: suzooky87 wrote: Thank you all for your input. I feel much better about using these housings. Just hope I have not offended anyone. Will let u know if they break once I put them in the Lwb. The plans are to lift (the least I need to make it work) lock ( front air, back lock rite) gear ( 6.5 transfer) big 33" maxxis bighorns tyres with f100 wheels. Will take me a fair while to do it all while I am at uni for the next 3 years, still buying parts, plans will prob change. Any way, thanks alot  If you are getting an air locker put it in the back for better on road manners, and power steering for the front. I was always under the assumption front air was the way to go. Aids in steering ability I thought
Have a look at all the threads on here and all the people that whinge about how crap the autos are on road, banging and clanging all the time and somehow forcing them to change lanes uncontrollably. A decent power steering setup should be sufficent to overcome any heavier steering.
steak_knife
 Posted: Sun Jun 12, 2011 4:35 am |
Red89 wrote: [ Have a look at all the threads on here and all the people that whinge about how crap the autos are on road, banging and clanging all the time and somehow forcing them to change lanes uncontrollably. A decent power steering setup should be sufficent to overcome any heavier steering.
But won't over come the no turning in mud, try to climb something slippery & you can't turn....
Red89
 Posted: Sun Jun 12, 2011 4:44 am |
steak_knife wrote: Red89 wrote: [ Have a look at all the threads on here and all the people that whinge about how crap the autos are on road, banging and clanging all the time and somehow forcing them to change lanes uncontrollably. A decent power steering setup should be sufficent to overcome any heavier steering. But won't over come the no turning in mud, try to climb something slippery & you can't turn....
True, but if you are going to have one auto and one air, and the vehicle will spend most of its life on the road, then on road manners is what most people complain about with auto lockers.
Rusho
That's what I was kind of getting at
steak_knife
Rusho wrote: steak_knife wrote: Red89 wrote: [ Have a look at all the threads on here and all the people that whinge about how crap the autos are on road, banging and clanging all the time and somehow forcing them to change lanes uncontrollably. A decent power steering setup should be sufficent to overcome any heavier steering. But won't over come the no turning in mud, try to climb something slippery & you can't turn.... That's what I was kind of getting at
Should of just said it then....
