It is currently Fri Nov 13, 2026 4:58 am
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Jun 19, 2011 3:58 am
did u know that EXEDY clutches make 2 Heavy Duty clutches for a 1995 SJ70 Sierra.
they make 2 due to the sierra either having a resessed fly wheel or flat one and either 18 or 20 spline on the gearbox and theres no outside evidence of which one your sierra has.
they have two different
1. SZK-6474HD Size, Spline OD & No. of Teeth 190 x 22.4 x 20
Flywheel Profile: -2.1mm
2. SZK-6293HD Size, Spline OD & No. of Teeth 190 x 19.1 x 18
Flywheel Profile: Flat
and a button clutch, SZK-6293HDB Size, Spline OD & No. of Teeth 190 x 19.1 x 18
all spigot bearings are 6000
so make sure u check which one u have before going to buy one so u dont get the wrong one. :helloo:
95 Sierra SJ70 TinTop
Vehicle: Daisy
Post Posted: Sun Jun 19, 2011 4:03 am
No but can you put the fact that this is clutch info in the thread title? Will make it a bit easier when I forget this fact and go to search for it in the future!
Thanks for the info though, do you reckon this could be checked through the bellhousing inspection port?
Post Posted: Sun Jun 19, 2011 4:12 am
on a 1l gearbox you can but not a 1.3 gearbox
Post Posted: Sun Jun 19, 2011 4:42 am
How much were you quoted for an Excedy clutch? I think i'll need to do mine in the near-ish future.
Vehicle: Daisy
Post Posted: Sun Jun 19, 2011 4:44 am
Nice, that's way better info that you first put there :p
Anyhow time to go wheeling, I'll put this thread in my memory bank for later!
Post Posted: Sun Jun 19, 2011 4:48 am
best quote i got was from North Brisbane Truck Spares
32 South Pine Road, Strathpine, QLD 4500
Brisbane City North, Pine Rivers
p: +61 3205 7800 f: +61 3205 1538
http://www.truck-spares.com
$263.00 and either $10 bucks postage or $30 for overnight
the dearest quote i got was from ABS auto brake service pine rivers in brendale $450.00
Post Posted: Sun Jun 19, 2011 5:17 am
buy protex brand, its exedy inside and $170 for a HD
if youd searched any of them part numbers youd find all that info already posted :wink:
Post Posted: Sun Jun 19, 2011 5:32 am
I can't believe you are endorsing Exedy HD clutches for a sierra 8O
Post Posted: Sun Jun 19, 2011 5:34 am
Exedy HD in a sierra work great, its Vitaras they are up the shit
I was rolling around in one with a hd clutch today, lovely pedal feel and bite
Post Posted: Sun Jun 19, 2011 5:35 am
Was shit in mine. Snapped cables.
They are a great clutch, but IMO better suited to vehicles with a slave cyl.
Post Posted: Sun Jun 19, 2011 5:36 am
Yes!!
Unless im super lucky but I've had 2 of these clutches now and no issues what so ever! Nice pedal feel and very controllable 8)
Lil Foot!
Vehicle: 4wd
Post Posted: Sun Jun 19, 2011 6:12 am
It's all been covered here but a bit harder to find when searching.
Watch out or you'll get sued.
Post Posted: Sun Jun 19, 2011 6:35 am
Don't know what yours was but my hd clutch from them is really lite and hooks up awesome. Handles good up with No slip. Mine had the pink pressure plate.
Post Posted: Sun Jun 19, 2011 7:19 am
If you ever see a recessed 1.3 flywheel, have a real good look cause you'll probably never see another one.
None of the 40 odd Sierras of various years I've wrecked have had one.
Post Posted: Sun Jun 19, 2011 7:28 am
Yes!!
I'll vouch for JrZook's car's clutch being friggin awesome!!! :D
Clearance Hole Technology :P
Post Posted: Sun Jun 19, 2011 8:10 am
Ok what is with the 18 or 20 spline gearbox input shaft he is talking about, aren't all 1300's 20 spline and LJ's + 1 Litres 18 spline
Post Posted: Sun Jun 19, 2011 9:37 am
All NT 1.3 are recessed!
Vehicle: 4wd
Post Posted: Sun Jun 19, 2011 9:41 am
Thats what I was told by the machine bloke. But he said to always check as at some point it might of been changed over for what ever reason.
He also charges more to machine the flywheels with the step.
Post Posted: Sun Jun 19, 2011 10:19 am
recessed flywheel from a SJ50 widetrack
Post Posted: Sun Jun 19, 2011 11:54 pm
I dunno about that... :? I've wrecked a heap of NT's and never seen one...
Only recessed flywheel I've seen in Suzuki is one litre and swift.
Post Posted: Mon Jun 20, 2011 12:37 am
Exedy dont even list a flat flywheel clutch for SJ50
The flat 18 spline are the rare ones for 1.3, Losfer even says he has never seen one, mine had it though :(
Post Posted: Mon Jun 20, 2011 2:14 am
All of the Sierras have them here. I think we ended up with what you wold call a wide track after 1986. They all came out with carbed 1.3 and the stepped flywheel until 91 when they went injection , but still stepped.
Users browsing this forum: Google [Bot] and 73 guests
