It is currently Thu Nov 12, 2026 9:56 pm
Post Posted: Tue Jun 21, 2011 12:13 pm
Hi. Was wondering if anyone can tell me where to buy a good quality 2" bodylift kit for a LWB vitara from? Preferably one that comes with brackets for front and rear bumper relocation. Oh yeah, I have an ARB bullbar. Would that be more complicated to re-mount than a stock bumper?
Also, do you need to modify the gear shifters with a 2" body lift?
Thanks in advance.
Post Posted: Tue Jun 21, 2011 12:14 pm
Here
Post Posted: Wed Jun 22, 2011 7:01 am
Rear bumper relocation is quite simple im sure if your capable of installing a body lift yourself, you should be able to sought out the rear Bar support. as for the front...
invest in a bullbar and modify that to the right height ;)
Stocker
Post Posted: Wed Jun 22, 2011 9:08 am
Cool. I already have an arb steel bullbar. Shouldn,t be too hard to modify with a grinder and a weld or two.
Post Posted: Wed Jun 22, 2011 9:20 am
damn straight... id go with Two on the welds being that there is 2 brackets you need to modify :twisted:
I used a bit of 25mm RHS, welded 2 pieces together, then welded that to the bar support. then a bit of threaded rod up the guts to hold the bar support on
Stocker
Users browsing this forum: pete_79 and 65 guests
