It is currently Fri Nov 06, 2026 7:20 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Post Posted: Tue Jun 28, 2011 9:10 pm
I'll suss out the barrel too then.
Post Posted: Tue Jun 28, 2011 9:19 pm
if its in the barrel, when it cuts out you will have no reds on the dash.
Post Posted: Tue Jun 28, 2011 9:31 pm
Not the barrel then.
Post Posted: Tue Jun 28, 2011 9:40 pm
yeah, it behaves like a dead fuse link.
Post Posted: Tue Jun 28, 2011 10:29 pm
test light will tell you enough, you want the light to light up heaps on the positive terminal and flash when connected probe to positive, clip to negative
easy thing to do first is pull a lead and check for spark
I am guessing a module or coil breaking down from heat, once it cools down some off it goes again
Post Posted: Tue Jun 28, 2011 10:31 pm
I am guessing a module or coil breaking down from heat, once it cools down some off it goes again[/quote]
x2
Post Posted: Wed Jun 29, 2011 7:16 am
Okay. Just got home and had a look.
It lights up real bright as you said. and clip on neg and probe on positive it sort of flickers in relation to revs its noticeable if you look at it hard enough but i wouldnt say its switching on off on off.
Post Posted: Wed Jun 29, 2011 7:20 am
thats what it should do, but do you still have power there when it dies?
Post Posted: Wed Jun 29, 2011 7:26 am
i cant get it to die.. it really only does it when im driving. and when i get home and have a go at fixing it.
Post Posted: Wed Jun 29, 2011 10:28 am
nope you gotta do it when its broken, no point trying to fault find when the fault isnt present
Post Posted: Wed Jun 29, 2011 10:34 am
keep a testlight in the car, next time it die's check coil positive if it's good clip the clamp on the test light to coil negative and the probe end to battery positve, wind it over as if you are trying to start it, if the test light flickers really fast get a new coil, if not get a new ignition module.
Post Posted: Wed Jun 29, 2011 10:56 am
whats the ignition module?
Post Posted: Wed Jun 29, 2011 10:58 am
its inside the dizzy, converts the magnetic pulse from the reluctor in the dissy to a switched signal to trigger the coil
Post Posted: Wed Jun 29, 2011 11:01 am
Ah okay. Shall test again tomorrow.
Cheers.
Post Posted: Thu Jun 30, 2011 9:23 am
how did it go dan..interested in the outcome myself.
Post Posted: Thu Jun 30, 2011 9:28 am
Ended being a clip connector thing was had it and sometimes didnt give a connection.
When it died i traced it back to there. limped home and hard wired it and the rest of the wiring near by so everything was fresh and strong. gave everything a wd-40 clean and rub with emery cloth. Good as new!
Thanks for the help guys.
Post Posted: Thu Jun 30, 2011 9:33 am
what clip connector thing where, was it on the valve cap? :roll:
Post Posted: Thu Jun 30, 2011 9:37 am
In line on the positive side to the coil. a quick connector thing.
Post Posted: Thu Jun 30, 2011 10:03 am
SierraDan wrote:
JrZook wrote:
Start off by checking all the wiring and connectors to the dizzy and coil. Pull em apart and clean them. Check all the earth's as well.
Run the thing at night and have a look under the bonnet in the dark and check for sparks around the dizzy and coil.
I've checked all the connections they're all good.
So check for sparks coming from the insulation?
I did get an awesome shock the other week..
:P
Lil Foot!
Post Posted: Thu Jun 30, 2011 10:04 am
:P
Haha yeah. This one tricked me! Taking the test light with me so i had it while it was dead helped. Rather than having it at home.. running fine.
Users browsing this forum: Google [Bot] and 119 guests
