It is currently Sat Nov 07, 2026 11:14 am
Post Posted: Tue Jun 28, 2011 1:34 pm
hi guys just got a 92 swb sierra with a 97 1.6 fuel injected motor in it. the wiring is not hooked up and im having trouble working it out. ive sat for ages with a wiring diagram and still not quite sure. i have the sierra loom connected so i have lights etc. but i cant get power to the ecu. anyone have a diagram on witch wires from the 1.6 loom i need to join into the sierra loom? ive read you only need about 5 wires hooked up for it to run but witch 5 wires are they =O. cheers
Post Posted: Tue Jun 28, 2011 8:46 pm
You need power from ignition ON to the two relays. One is fuel pump. One is ECU.
If you get stuck send it to Steve at KillaKustomKables.
If I had more idea of your location than just Australia I would be able to recommend someone close to you.
Post Posted: Tue Jun 28, 2011 8:59 pm
hay want33s any idea what it is worth to get a loom sorted?
Post Posted: Tue Jun 28, 2011 9:48 pm
forgot to mention my loom was cut wen it was removed from the vitara but im pretty sure after goin through diagram after diagram ive still got all the wires i need. just dont know were to join into the siera loom. and thanks want33s that put me on the right track i reken
Post Posted: Tue Jun 28, 2011 11:24 pm
I have an idea he is on ebay, do a search and send him a PM he will send you a quote.
Post Posted: Wed Jun 29, 2011 1:01 am
Shep.... Anything up to $400 I believe..
He did mine cheaper as I was guinea pig...
It is plug and play once done... I'm sure you could handle it without much hammering... :wink:
Post Posted: Wed Jun 29, 2011 9:11 am
what coloured wires from the vitara loom need to go to the sierra loom? are they only wires that go from vitara loom the ones from the relays?. so i get power to relays then i shld be on track? i cant work out were to splice in.
Post Posted: Wed Jun 29, 2011 9:46 am
any1?
Post Posted: Wed Jun 29, 2011 10:04 am
Vit uses some different color's..
Where are you?????
What eng????
Post Posted: Wed Jun 29, 2011 10:06 am
Black/white with black/white, thats ign
Black/yellow with Black/yellow thats crank if its manual ecu.
Violet and think yellow trace is constant power.
I sent you a link that should help
Suzuki is my way of life.
Post Posted: Wed Jun 29, 2011 10:54 am
Simplified schematics.
The page
http://www.kick-fix.com/ECU/8v-tbi-schematic91to95.jpg
Link where I found it.
http://www.kick-fix.com/schematics-run.html
Post Posted: Fri Jul 01, 2011 9:02 am
bit of an update got both relays clicking, f/p priming but with key in the "on" position for about 30 seconds smoke came out my ecu =O. took the cover off the ecu and all still seems to be fine one of the little wires just got a bit hot. so im guessing its shorting out somewere? any ideas
Post Posted: Fri Jul 01, 2011 11:27 am
ok. got the engine cranking but the wire in the ecu is still getting way to hot. ideas?
Post Posted: Fri Jul 01, 2011 12:25 pm
dude i would take it to a auto eleci. sorry to be the one to say it.
Post Posted: Fri Jul 01, 2011 12:45 pm
i new that was comin lol
Post Posted: Sat Jul 02, 2011 4:07 am
if my f/p isnt connected and the pink wire is just hanging free. wld that cause something in the ecu to draw to much power?
Vehicle: Sierra 1992 1.6L
Post Posted: Sat Jul 02, 2011 11:50 am
What color is the wire that is getting hot?
What color are the plugs that go into the ECU?
Still have copies of all the wiring diagrams that i used so might be able to help you out
Post Posted: Sun Jul 03, 2011 5:19 am
this is whats getting hot. the plugs are 2 blue plugs.
Post Posted: Sun Jul 03, 2011 6:08 am
ok just checked and have got no spark. will chek dizzy wiring later and hopefully theres a wire not connected causing ecu wire to get hot
Post Posted: Sun Jul 03, 2011 6:21 am
I dont think not having a wire connected will cook a diode in the ecu, more a case of having a wire connected wrong. I aint no expert but I would be taking jonno_racings advice
Post Posted: Sun Jul 03, 2011 9:45 am
Mine was White (comp) for constant power and i hooked it to White/Green trace (sierra horn).
With it getting hot try to find which pinout that resister goes to and find what wire colour it goes to. Chances are its hooked to a ground/positive it shouldnt be.
Post Posted: Sun Jul 03, 2011 11:09 am
so the white wire out of the ecu was constant power not the violet/yellow? maybe ill try that
Post Posted: Sun Jul 03, 2011 11:26 am
bingo! haha thanx for that the diode thingy isnt getting hot anymore and everything still works just gotta try get spark now. thanx
Post Posted: Sun Jul 03, 2011 1:05 pm
another thing to annoy u guys with is this. is there supposto be a hose from this pipe on the inlet manifold to the intake pipe?
Post Posted: Sun Jul 03, 2011 1:46 pm
yes there should be a hose connecting them two pipes
White wire is constant 12V
violet/yellow is check engine light
Post Posted: Sun Jul 03, 2011 1:48 pm
PM me your email address and i will email the diagram that i used to wire mine up, My comp had the 2 blue plugs aswell
Users browsing this forum: No registered users and 49 guests
