It is currently Thu Nov 12, 2026 7:48 am
Vehicle: 2018 DMAX
Post Posted: Sun Jul 03, 2011 4:09 am
Mite be usefull for some one wanting to swap dashes. As this swap uses the NT surround, you will loose your engine check light and seat belt light.
I have edited the post, shows how to swap the light panel over aswell..
If you are doing this swap into a NT, with a NT harness you may need to confirm it will work against a wiring diagram. As there are minor differences to the clusters.
Looking at the front the WT cluster looks larger than the NT. Essentially the surround is the only difference.
First remove the surrounds from both clusters. The NT surround pulls off when its removed from the dash, followed by a further two screws to hold the perspex cover on. The WT has 8 screws on the back to remove. When you compare the two, the WT has extra mounting holes all around, but other than those the main body of the cluster is the same.
Next step is to grab the NT perspex cover and sit it on the WT cluster. The two screw holes for mounting the perspex will line up. Look around the outside, and take note of the 4 screw holes that it lines up. You will need to keep these when you trim the excess ones down.
Now its time to start trimming. I used a hacksaw blade and a hot knife. A dremel, small hand saw or angle grinder could be used here. You can see where i have trimmed here. The bottom mounting holes on the WT have extra plastic behind them for added strength, and will interfier with the NT dash.
Swapping the light panels will allow you to keep you check engine and seatbelt lights. Remove the two light bars and then remove each light panel. The WT panel is sitting on two pins, the NT is glued down, but with its age pops out pretty easy.
Get the two panels, and hold them face to face upto a light source. Line indicators up, make sure you have the 4WD light on the same end. The WT panel sticks out around 10mm on each side, trim this off with some scissors.
Then stick the WT panel down into the NT light bar, i used a drop of superglue in each corner. Make sure its the right way up.
Once thats complete you ready to reassemble eveything. I gave the NT perspex a clean up, but it has a crack in it and i will find a good condition replacment at some time. Place the perspex onto the WT cluster and insert the two screws, followed by the light bar whice is held down with another two screws. Again the perspex was shagged on my light bar, so i left it off for now. Then sit the NT surround over t and it should bolt up to your dash now.
This is the differance between the light bars. WT top, NT bottom.
There is other ways of doing this. You could swap all the internals from the WT cluster into the NT, or you could even try swap the gauge backing panels. But my way there was less chance of breaking the gauge mechanisms.
Last edited by boostedbrick on Sun Jul 03, 2011 11:42 pm, edited 2 times in total.
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Jul 03, 2011 5:00 am
Awesome, that came up pretty well.
Good to see all the parts in detail too - sorting the dash is another job on my list
Post Posted: Sun Jul 03, 2011 10:34 am
Whats the advantage of having the WT cluster?
EG as you say you loose the Check Engine and the Seat Belt.
But what has the WT got that the NT has not seeing as you already have a tacho?
I was thinking of putting a WT in my NT to gain a tacho and the check engine light.
Great write by the way, very easy to follow.
Vehicle: 2018 DMAX
Post Posted: Sun Jul 03, 2011 11:44 am
As far as i know there is no difference other than a more modern look. The back of the clusters have some minor differences but presumably the wiring is the same. Ill get some comparison photos tomorrow.
If you wanted to keep the check engine light, you could remove the panel from the WT light bar, and trim it to fit into the NT light bar. Ill have a look at this tomorrow as I have the bits there. It should be easy to do.
Post Posted: Sun Jul 03, 2011 7:08 pm
Good write up so do you think there would be any way i could fit the nt surround to my wt cluster in my wt as i think that the surroun looks better
Vehicle: 2018 DMAX
Post Posted: Sun Jul 03, 2011 11:23 pm
I had a play with it, and its actually quite easy to swap the panels from the light bars over, ill update the first post with the details..
Had a look at the back of them aswell, there is minor differences. So this swap will work if you are using a WT harness(nt dash into wt), but would need some more research to go the other way.
honks, the nt surround is alot smaller than the wt. It would fit but look pretty shithouse.
Post Posted: Mon Jul 04, 2011 9:20 am
Do you have a pic of the backside of your dash at all?
Post Posted: Mon Jul 04, 2011 10:03 am
Well done, Have done this a couple of times myself. just never thought of taking pics and posting. If you want to swap the flexy board on the back you need to swap a pin position for the hand brake light down or up one ternimal on the drivers side plug as well, pritty simple when you look at the board.
Suzuki is my way of life.
Vehicle: 2018 DMAX
Post Posted: Mon Jul 04, 2011 10:23 am
WT top, NT bottom... Taylor74, left hand side of the board if your looking at it?
Post Posted: Mon Jul 04, 2011 10:52 am
Was meaning the wiering harness is on the drivers side, soz for the confusion.
Users browsing this forum: Google Adsense [Bot] and 108 guests
