It is currently Fri Nov 06, 2026 11:58 pm
Vehicle: Sj70 tintop
Post Posted: Mon Jul 11, 2011 8:03 am
94 maruti tray back
since ive fitted my 2" lift and tough dog rtc coiled steering dampener, my steering wheel has started to go more and more upside down, it was always slighly just off, but today its nearly upside down.
steering is still fine and doesnt pull or drag to one side at all, even under brakes.
whats the prob, i know this happens with coiled trucks when you lift them and dont have caster bushes etc, but i didnt think this could be so far out on a leafy, is this a caster problem, i didnt think so as its only 2" higher than standard, or is it the rtc dampener, have i not set it up properly?
how do i fix this? rip the steering wheel off and re set it in the proper position? or do i have a bent steering arm?
any help thanks in advance.
cheers
joel
Sj70 tintop
Post Posted: Mon Jul 11, 2011 8:06 am
Its not a castor problem...
When you lift the car, the geometry of the steering components changes... When the wheels are straight ahead, the pitman arm is not in the same position it used to be, its actually turned slightly, so with the steering wheel straight the wheels actually point slightly to the right (from memory)...
I want my old sig back :(
Post Posted: Mon Jul 11, 2011 8:07 am
from only 2'' lift?
how do i fix this?
drop pitman arm or?
Sj70 tintop
Post Posted: Mon Jul 11, 2011 8:10 am
Drop pitman arm would be the best solution, yes...
Post Posted: Mon Jul 11, 2011 8:12 am
Just pull the steering wheel and put it back on in the right alignment. There's no other adjustment in the system. This is 100% normal, and 2" is 40% of your front wheel travel, so it's a significant amount.
If the straight ahead position of the steering wheel changes day to day, you have something loose and you need to find what that is.
(PS as Ben said, it's nothing to do with caster, only lift)
Post Posted: Mon Jul 11, 2011 8:14 am
Does the steering box only turn so far in each direction, or is steering lock determined another way? If it was in the box then you would lose about half a turn in one direction and gain about half a turn in the other?
Post Posted: Mon Jul 11, 2011 8:19 am
i think if i got the wheels straight, than ripped the steering wheel off and aligned it so its straight also, that would negate that problem i presume ben?
Sj70 tintop
Users browsing this forum: No registered users and 73 guests
